Old 10-01-2016, 11:12 AM   #1
Satellite Install
I have found that this forum is invaluable. Installing a crank up satellite dish on my 335. I know that there are cables on the roof in the "fake sewage vent" but before starting I have seen a lot of traffic about where they go and how they are connected. Fortunately I communicated with JimF since he had a post about accessing the cables from the center overhead cabinet. PM'd him and he told me to pry up the lower cabinet back in the center cabinet.
Well...I did and it was just as he indicated. Here is what I found after prying off the trim (3 sides glued to the panel) and prying out two staples on the upper side of the panel. The false panel covering this hole was not glued in any way. Obviously a couple of screws could have held it into place and made it easily removable. I can imagine how long it would take me to get an answer on this from the factory!!!!
Now, I didn't make that rough cut, the factory did and covered it with a nice clean panel. By the way, those 3 cut cables in the foreground are the cables from the roof and clearly don't go anywhere anyway. Splitter had some slightly loose F connectors as well.
Now to pull the new cables from the roof and push them into the passenger side compartment.
A picture is worth a thousand words, this forum...millions!!!
Thank you JimF!!!!!
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-01-2016, 04:28 PM   #2
Iggy's Avatar
Is this location where the TV antenna amp is also mounted?
Humm. I will have to check mine as I have always wanted to check out that splitter but was unable to pull it up to get to it.
Maybe I also have a panel over the larger hole.
You might consider adding this to the Georgetown forum area. I think other may find it interesting.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 10-02-2016, 06:18 AM   #3
Nope, its in the center compartment, lower panel. Came out relatively easily once the trim was removed with a putty knife and the two staples were pulled out. The are only into the 1/8 inch plywood shown in the picture so they come out easy.
2015 335DS
satellite
