Old 12-13-2008, 10:41 AM   #1
Satellite Sound
For the first time, I hooked up my satellite to this unit and had great picture but no sound. Tried Input 1 or 2 as well as switching both at the wall plate. If you listen very closely (like your ear on a speaker close) you can hear the sound. Its like sound is reaching the ZX-600 but not powered to the speakers. I've toggled the A/B/C switches with no luck. Thoughts?
kphammer is offline   Reply With Quote
Old 12-13-2008, 06:17 PM   #2
Cyber Phrenologist
Radio's Avatar
I assume the audio output of the satellite box is through 2 "RCA" connectors that you run to the wall plate. If that's the case, find something else with audio inputs (like a "boom box") and run the audio into that.
If you can hear it there, the problem is the Concertone or the wiring of the wall plate.
If you still can't hear it, the satellite box is the problem.
This assumes the Concertone plays all the other audio inputs OK, right?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 12-16-2008, 09:02 PM   #3
Good suggestion on trying another device with audio ins. I'll see if that works. I need to take my trailer in for warantee work (oven pilot will not stay lit) so I may just have them look at it.
Thanks again
