On my pervious camper, a Cougar 318SA I needed to add a satellite hook-up for my Dish Tailgater since there was no satellite hook-up on that model. What I did was drilled a hole (7/16") in one of the rear slides that the TV was installed in. This was drilled in the floor inside a cabinet a cable plate was installed on the outside under the trailer and the connection passed through this hole. This was an outdoor connector that allowed you to screw the cable into and then removed the cable before closing the slide. The inside was permeant attached to the cable box with a cable from the outside connector and cable box.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
