Old 03-02-2015, 12:36 PM   #11
TURBS's Avatar
Originally Posted by HIDE OUT View Post
so I can have one tv hooked to the hdmi and the other tv run out of the receiver with one of these and run the br with a ir remote
In theory it should work.
TURBS
Old 03-02-2015, 12:49 PM   #12
Crockett's Avatar
thank you gents...all this was clearly over my head...
Crockett is offline   Reply With Quote
Old 03-02-2015, 01:10 PM   #13
john1345's Avatar
Ok what I did when I had one Sat rec I put the sat rec before the switch box. and I used the remote to change the channels on the Sat rec. So all I had to do was select what tv I wanted to watch. Better yet if you don't have a selectable switch box. just take the output of the Sat Rec run it thru the HDMI to Cable converter then in to the input of the switching unit. Then use the IR or RF remote unit, to control the channels on the sat rec. another way you may be able to do it some of the new sat rec remote controls use Rf to control the link between the sat rec and is remote. This type of remote will transmit thru walls for a short distance. remember to have you TV on channel 3 or 4 and control every thing with the sat rec remote.
john1345 is offline   Reply With Quote
Old 03-02-2015, 01:44 PM   #14
member
now I am really confused what switch box?? with the tailgater it has to be a direct run from ant to rec or it wont work.so the switch your talking about connects from the rec hdmi out to the switch the to the TV's?
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 03-02-2015, 01:59 PM   #15
john1345's Avatar
ok if you don't have a second tv don't worry about the switching unit then
Old 03-02-2015, 02:17 PM   #16
member
I do have a second tv one in the bed room and one in the living room
Old 03-02-2015, 03:55 PM   #17
My recommendation is don't bother with satellite in the bedroom. I found that you just won't use it that much. Use your roof antenna for the bedroom tv while you are dozing off.
palmetto rogue is offline   Reply With Quote
Old 03-02-2015, 04:12 PM   #18
stansoper's Avatar
I have the same set up and a tailgater in my Wildwood TT. The sat only runs to the sat in the living room. That's because the sat in cannot be split. That's why you don't have a sat connection in the br. To get sat in the br you would have to figure out how you could run from the hdmi out on the tv in the lr to the tv in the br and that's a long run for hdmi. I'm going to watch antenna (HD) in the bed room and sat (HD) in the living room, since most of the TV watching will be done in the living room anyway. These manufacturers are not always satellite friendly.
stansoper is offline   Reply With Quote
Old 03-02-2015, 04:28 PM   #19
member
I do have a sat connection in the bed room
Old 03-02-2015, 04:50 PM   #20
stansoper's Avatar
That's interesting. I don't, only in the lr. I suppose if you had a joey set up it would work. With dish the coax from the dish runs to a receiver and then to TV. I don't have a clue how you would do it with your set up. I think you would need two receivers. Sorry can't help more. Maybe you will need to have a dish technician look at it.
satellite
