Old 03-30-2015, 08:22 AM   #1
satellite tv, local programming
Ok, I got the extra dish, tripod, etc. Set it all up home in the driveway. All went fine. Did the same on our trip and again it worked; however, no local channels. It's not a problem now, I'm in Memphis. Local broadcasts over the air. My issue is for remote areas with no over the air signals. Direct tv tells me local programming is not available away from home. Is this the case with all dishes?
pcbikenski is offline   Reply With Quote
Old 03-30-2015, 08:32 AM   #2
TURBS's Avatar
You just need to call your satellite provider and tell them what zip code your in.
They'll change your locals to that zip code.
Albeit it will be the local channels where your at not @ home.
Yes there all Like that.
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 03-30-2015, 08:34 AM   #3
Berkshire 390QS
NO3putt's Avatar
With DISH network we just call them and tell them to change the "service address" and we get local chanels for where we are at. Do you have a seperate RV account with Direct or just using your home account?
Old 03-30-2015, 09:54 AM   #4
Just the home I think, but I told them I wanted it for my motorhome!????
Old 03-30-2015, 12:28 PM   #5
plshilo's Avatar
Most of the people with Dish are off in "O" Zone and have to explain that you are in a RV to get the local stuff then Don't forget to call them on the way home to get them Changed Back to the home address..... Good Luck
Phil & Linda and our two four legged girls - Cricket & Lucy
2016 F350 Super Duty
2011 Prime Time 27.0 RET Crusader 5th Wheel
plshilo is offline   Reply With Quote
Old 03-30-2015, 12:34 PM   #6
No3putt is correct. However, DISH will only let u have a service address on one acct. every time I changed my service address to my RV location that also changed my local channels I had at my home. Since I had grown kids at home they weren't keen watching Fl locals when they were still in Mi.
I finally, got an RV account that I put on on when not traveling.
Another option is to buy a better TV antenna for your locals.
Hope this helps.
Pkowski is offline   Reply With Quote
Old 03-30-2015, 12:38 PM   #7
TURBS's Avatar
I don't think this is possible.
For the same reason when you leave your home area you can't receive home locals, if you have your service switched to Florida your home dish won't receive FL locals sorry.
TURBS
Old 03-30-2015, 12:51 PM   #8
In stand corrected. I did not receive any locals at the home. Sorry for the confusion
Old 03-30-2015, 12:53 PM   #9
TURBS's Avatar
No problem!
TURBS
Old 03-30-2015, 01:47 PM   #10
Old Timer
Looks like all the respondents so far have Dish. With DirecTV it depends on what kind of satellite dish antenna you are using. Any plain round dish will not receive the locals when aimed for the other channels, nor will it receive programming in HD (presumably) Nevertheless, I use a Winegard Carryout Anser (easy aiming) with my DirecTV receiver in the 5er. Picture quality when properly aimed is way good for me. I rely on the OTA (antenna) for local channels wherever I am. If I were using the triple LNB oval DirecTV antenna I could receive local channels, but they would be from here at home no matter where I was (I think).
Well that's my two bits worth from a DirecTV fan.
kentnjudy is offline   Reply With Quote
satellite
