Old 12-24-2015, 06:49 PM   #1
wmbuttion's Avatar
Satellite TV problem
No reception if I run through unit. Reception if I bypass unit & run cable to receiver. Any help are there any buttons u have to press? Merry Christmas to everyone out there.
wmbuttion is offline   Reply With Quote
Old 12-24-2015, 07:04 PM   #2
Its hard to say for sure without seeing how they wired your unit. If they have 2 coax ports outside with one marked sat, sometimes you have to connect a jumper inside the unit. Usually though, that exact situation you describe is caused by a splitter in the wiring which is not a power pass splitter somewhere between the receiver and dish. Any splitter between receiver and dish has to be power pass.
Mr Havercamp is offline   Reply With Quote
Old 12-24-2015, 07:08 PM   #3
wmbuttion's Avatar
It's a Ceder Creek 2015 has Bed room & a living room satellite hook up & one for cable
Old 12-25-2015, 11:33 AM   #4
Left Coast
Turn antenna booster off?
Old 12-25-2015, 11:53 AM   #5
wmbuttion's Avatar
Is it behind main TV. Can't get main TV to move out from wall
Old 12-30-2015, 09:39 PM   #6
depends on your unit i guess. I know the XLR guys have some headaches when using a sat
In my particular case though, the booster for the antenna is in the cox connector in the garage, it HAS to be turned off for the satellite to work.
the booster likely looks something like this:
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 12-30-2015, 09:46 PM   #7
Ambassador
Ken K.'s Avatar
is it possible that the cables got switched at one end or the other at some point? put a dead end connection on one end and get an ohm meter and see whats connected to what. By dead end connection I mean hook a short cable on one end and jump the connection between the middle coax wire and the outside. So, when you use an ohm meter on the other end, it will complete the circuit and tell you what's connected to what. If you get no movement on either then your cable has been shorted, or cut some where in between, thus you'll need to run new cable. Good luck.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-30-2015, 10:37 PM   #8
wmbuttion's Avatar
Thank u
satellite
