Old 07-28-2016, 06:56 PM   #1
Sewer smell when A/C is running
We have a 28' Coachmen Apex. This is our 3rd summer with it. While out camping last week, we turned on the air and after awhile it began to smell like sewage in our trailer. The black and gray tanks were both closed. I felt like the smell was the worst when I would open the bathroom sink cabinet. I have a hard enough time running the air because it is loud and now with this smell, I really don't want to even turn it on. I faintly remember this happening last summer too. Please help!
thickly settled is offline   Reply With Quote
Old 07-28-2016, 07:19 PM   #2
NMWildcat's Avatar
I would think the smell is being drawn into your rig by the a/c from your rooftop sewer vents. If that's the case there are different types of vent pipe covers you can try. Also might want to switch the chemicals you use in your tanks. We use Odorlos and rarely have any smell issues.
Scott and Liz - Southern NM
Old 07-28-2016, 07:41 PM   #3
NMWildcat's Avatar
Oh... Also check your a/c filter inside, and then go up on the roof, take off the shroud and make sure your drip pan is draining properly and not leaving stagnant water in the pan.
Old 07-28-2016, 08:12 PM   #4
We had the same problem with our Cedar Creek 34RL. I found a vent under the bathroom sink and replaced it. Since then.......no smell. You need to go to Home Depot and get one of these: Oatey 1-1/2 in. ABS PTC In-Line Cheater Vent-39012 - The Home Depot
It is a one-way vent that allows air to enter the waste tank. It is supposed to keep the foul air inside but sometimes they leak. Just replace it and you will be good-to-go.
dbunhook is offline   Reply With Quote
Old 07-28-2016, 08:26 PM   #5
It sounds like the air admittance valve, as mentioned above. Easy to clean, or perhaps replace. Look for it under the bathroom sink. It is pvc and just screws on.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 07-28-2016, 09:20 PM   #6
NMWildcat's Avatar
Learned something new today! I've never heard of a vent inside the rig! I looked at ours and thankfully don't have one. Thanks for the new info!!!
Old 07-28-2016, 09:27 PM   #7
TURBS's Avatar
Besides that the a/c does not draw outside air to the inside.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
Old 07-28-2016, 09:34 PM   #8
NMWildcat's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Hey turbs! You know I've heard that, and know that's the way it's supposed to work but it sure seems like those nasty outside odors come in when the a/c is on
Old 07-29-2016, 12:39 PM   #9
Telstar's Avatar
Probably your air drawing in smell from the campgrounds sewer vent pipe. If you see a pipe sticking 8 to 10 feet up from the ground don't camp in that site.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 07-29-2016, 12:56 PM   #10
dannyabear's Avatar
IT'S there.........
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
