Old 04-12-2013, 10:58 PM   #1
Shower Enclosure Leak
Last trip out we noticed some water running across the floor. After some testing this evening I found out it is getting into the aluminum extrusion from the inside around the glass and since they caulked the interior from the factory it's taking the path of least resistance out and not in!
Not sure why these jokers at the factory can't figure this stuff out! I've attached some pictures for your viewing pleasure. I'm going to take it in tomorrow and let the dealer jack with it. I'll offer them my advice and report back when I get it back. I'm betting that I'll end up fixing it myself in the long run.
ID:	27761   Click image for larger version
ID:	27762   Click image for larger version
ID:	27763   Click image for larger version
TheGoodwin4 is offline   Reply With Quote
Old 04-12-2013, 10:59 PM   #2
This is on a 2013 palomino 356qlb.
Old 04-12-2013, 11:22 PM   #3
Fire Instructor's Avatar
Had the same problem on my 2607, straight from the factory. Re-siliconed the inside enclosure seams, and no more problem. This was the first "repair" that I had to make on my TT.....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-12-2013, 11:37 PM   #4
It's too bad the glass isn't just set in silicone vs. the rubber seal. That way at least the water would be expected to not run inside of the extrusion. I think the bottom of the track needs all the caulking removed and possibly some holes drilled in it on the inside to drain.
Old 04-13-2013, 05:16 PM   #5
Grape Escape
I think everyone of them will leak. Run a thin bead of clear silicon and wipe with finger on all points glass contacts seals and any other places alum meets base and walls. Problem solved. Won't even see it.
Still no way of dripping water onto floor when door is opened.
If this is all I need to worry about life must be too good.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-22-2013, 12:10 PM   #6
DKirk's Avatar
We just did our first "shakedown" overnighter this weekend with our "new" used 2011 Mini-Lite 2304 (if the previous owner used it you couldn't tell - it's like new) . We discovered that our shower has the exact same leak! DH is going to run some silicone this week.
So glad we decided to take showers in it yesterday rather than wait till we got home (only 20 miles away) or we wouldn't have found this problem until we were on our next trip which will be a 4 day weekend, 6 hours from home.
-Dawn
2011 Rockwood Mini Lite 2304
2004 GMC Savana 2500
2013 Days Camped, since April: 33
DKirk is offline   Reply With Quote
