Old 01-15-2014, 05:21 AM   #11
Mikegjax's Avatar
Do you have a satellite antenna in the RV?
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-15-2014, 06:56 AM   #12
When I had to replace our (XM) assy that was wired into the (Concertone) I finally paid the (14 year old) neighbor boy. Here was the Factory wire job? Youroo!!
ID:	44941   Click image for larger version
ID:	44942   Click image for larger version
Old 01-15-2014, 07:27 AM   #13
Witch Doctor's Avatar
I have the same unit, you need to find the mode it is connected to mine is connected AU2 mode on the Genesis 3. That will bring on the XM sound thru the system speakers. If not then it is not hooked up or your wire came loose. The picture above is exactly like what I found when I pulled the unit out. It is one big mess behind the unit itself.
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-15-2014, 10:03 PM   #14
Meweerv
Smile Xm radio
Thank you for the info mine is the same as in the picture.I will try the au modes again and if that dosn't work then it's back to the dealer for warranty repair i don't think I want to get into that rats nest
meweerv is offline   Reply With Quote
radio, satellite
