Old 03-21-2019, 09:29 PM   #1
Question slide, awning and jacks wont work
I have a 2107 224RLS VIBE and just got back from my first long trip. The electrical worked fine while on the trip but when I returned none off the 12v stuff worked. I couldn't even get the electric lift jack to work so I couldn't unhook my truck. I heard a clicking noise every 10-15 seconds from a relay under the trailer frame close to the battery. After some troubleshooting I found two red and white wires from the relay on the battery side measured directly to ground. When I disconnect these two 10-12 gauge wires all the 12v stuff works except the slide, awning and electric jacks under the trailer, the electric lift jack worked so I could disconnect my truck! Not really sure where the two red and white wires go and what to do next? Can't find a wiring diagram on line. Any help would be appreciated.
Berad
bmmillsx2 is offline   Reply With Quote
Old 03-21-2019, 09:34 PM   #2
that is allot to take in for a first post and I am not an electrical master. before disconnecting wires I would be looking at fuses/breakers and checking battery charge. Lots of knowledgeable folks should chime in but may want more info.
Kimber45 is offline   Reply With Quote
Old 03-21-2019, 09:44 PM   #3
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. I would say one red powers the jacks and the other the slide and the white wires ground. Are you saying all four wires were grounded?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-21-2019, 09:52 PM   #4
Thanks Kimber45 and Seadog
I did a little troubleshooting before finding the two shorted red/white wires. My inverter was surging going from 12v to 3v on my volt meter so I disconnected the 12v wire from the inverter going back to the battery and the rest of the 12v stuff worked so I assumed something was causing a load at the relay. There is only two red/white wires going back, I assume they are going to the jacks and slide.
Old 03-22-2019, 08:11 PM   #5
Low resistance
Berad
This can be a little tricky. Any high current load is low resistance. If you measure the resistance to ground, it will be close to 0 ohms. If you are using a high scale on your multimeter, it will look like a short to ground, even when it's normal. For example, assume the slide motor draws 30 amps at 12 volts. R=V/I, so the resistance will be 2.5 ohms.
The next step in troubleshooting will have to be "Divide and Conquer." Reconnect the white wire. It's a ground wire and the symptoms should not change. Now, get on your back and follow the red wire. It will probably go to a circuit breaker (small cubical box with a button on one end). On the other terminal of the circuit breaker will probably be multiple wires, one each for slide, awning, and jacks.
  • Disconnect all wires. Reconnect red wire to battery. Symptoms should be gone.
  • Disconnect red wire at battery. Put one wire on terminal. See if symptoms return.
  • Repeat with each of the wires until you identify which one causes the symptoms.
  • Disconnect everything but the wire that causes symptoms. Figure out which one thing isn't working. Look for a pinched or chafed wire near the failing item.
Larry
Larry-NC is online now   Reply With Quote
Old 03-22-2019, 09:08 PM   #6
Smile reply to Larry
Thanks, I took basic electronics so your reply makes sense. You confirm what I figured I need to do, hated to take the bottom off the trailer because it's sealed but I need to it so I can follow the red/white wire. Will let you know when I find the bad wire...
Thanks again
Berad
Old 03-22-2019, 09:17 PM   #7
dannyabear's Avatar
Any chance you turned tooo short and pinched the cord going to your truck? The large red and white wires feed the converter; jacks, stabilizers, and slide prob have there own fuse/circuit breaker usually under front of tongue below battery. Did you run over anything that could have pinched the wires underneth the trailer?
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
awning, jacks, slide
