Old 07-02-2019, 10:59 AM   #1
Smelly freezer
Lost power with food in freezer and refrigerator luckily not a big clean up mess But we have a smell problem, we cleaned with disinfectant wipes Several times then left newspapers and baking soda in freezer for a week tired a week door closed and a week door open.. Even tired putting charcoal in there . Made a paste of baking soda and cleaned entire unit. The refrigerator section itself isnít too bad but we canít get the smell out of the freezer it is really still rough We turned unit back on to see if any difference. Anybody have other suggestions ?
Rharrod3 is offline   Reply With Quote
Old 07-02-2019, 01:07 PM   #2
Kasual Kamper
You might try using a mild bleach solution. Wipe down the sides with a wet sponge, leave wet and then CLOSE the freezer door for about a half hour. Then rinse with clean water and let the compartment dry out completely with the door open.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 07-02-2019, 01:18 PM   #3
Ok. I forgot to mention I also used vinger the way you described It’s worth s try
Old 07-02-2019, 01:25 PM   #4
Kasual Kamper
Vinegar will make it smell worse, lol! You may need to repeat the bleach sequence a couple of times. Man, you must have had some nasty stuff in there!
Old 07-02-2019, 01:37 PM   #5
Originally Posted by Rharrod3 View Post
Lost power with food in freezer and refrigerator luckily not a big clean up mess But we have a smell problem, we cleaned with disinfectant wipes Several times then left newspapers and baking soda in freezer for a week tired a week door closed and a week door open.. Even tired putting charcoal in there . Made a paste of baking soda and cleaned entire unit. The refrigerator section itself isn’t too bad but we can’t get the smell out of the freezer it is really still rough We turned unit back on to see if any difference. Anybody have other suggestions ?
What kind of charcoal?
Only 'activated' charcoal (carbon) will work to remove tough odors.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-02-2019, 01:57 PM   #6
Iwannacamp's Avatar
I used to repair residential reefers.... best thing I ever used.... was X-14 Mildew and stain remover
2017 Puma 297RLSS
Old 07-02-2019, 02:04 PM   #7
Flybob's Avatar
It is likely that some of the thawed/melted liquid made its way into the cracks where the sides/back meet. You might make a mixture of Odoban and water and dribbling it along the cracks then closing it up. Odoban can be purchased at most big box stores.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
