Old 01-11-2014, 10:26 AM   #11
bubbles's Avatar
You didn't inadvertently set your tv for sap mode input did you?
Old 01-11-2014, 10:45 AM   #12
Cyber Phrenologist
Radio's Avatar
Originally Posted by King Yankee View Post
booster is off, connected to neighbors cable outlet, same issue. Thought I had it somewhat ok, wind blows and we're back to start. (?)
The problem is the park's cable TV distribution system. Not your camper.
The amplifiers in the system are "rolling off" the lower frequencies and allowing the signal level to get too close to the noise level inherent in all such systems. (The symptoms you describe indicate an old, analog system)
The signal should be strong enough so that the noise, which is always there, is not an issue. The signal is so weak the noise become obvious. Once this happens there is no way to "fix" the noisy signal. Filters won't take it out, and when you amplify noise, you get.... loud noise.
Don't try to fix anything in the camper. The problem isn't yours.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 01-11-2014, 09:27 PM   #13
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
then only question RADIO is why wouldn't it bother my campground neighbors too? Gets very frustrating to say the least. So far tonight it has been great watching the Pats.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 01-19-2014, 01:26 PM   #14
Cyber Phrenologist
Radio's Avatar
I thought when you said...
....you meant that the neighbors were in fact having the same issues as you. In that case it would be a campground issue. The wind blowing could be upsetting the shared community antenna.
If instead the neighbors are NOT having the same problem then it's back to fixing your rig. Again though I would look for something that would cause a frequency roll off, like an amplifier or booster.
Bummer. I was hoping to save you some time and money.
KU4OJ
Old 01-19-2014, 06:42 PM   #15
today for the NFL Playoffs I ran a cable directly from park hookup to our TV inside. No issues, so I guess I admit there is an issue with a booster or amp or amp as Radio says. I also added a splitter to run bedroom TV and everything works great. I had rewired as previously stated exactly as required so I assume it's the booster. (?) Anyhow until we leave this area April 1st I believe I'll leave the setup as I have it now. Thanks to everyone that tried to help me...until later. Bruce
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
snow
