Old 07-04-2012, 08:49 PM   #1
ejohnson03's Avatar
SOLVED- A/C breaker trips quickly
Hello, I am new to this forum.
We bought our Rockwood Roo 21SS at the Novi, MI camper show in 2010.
Just started having an issue when turning AC on, the blower sounds like it is not running at full RPM, and kicks off breaker after about 2 minutes.
Refrigderator is off, and all other electrical stuff is off.
Question is could this be a filter clog issue?
ejohnson03 is offline   Reply With Quote
Old 07-04-2012, 08:57 PM   #2
depo's Avatar
My question to you is what are plugged in to?
If you are in a 30 AMP, something is a foul.
If you are using an adapter to plug in to a standard 120 volt 15 AMP outlet, you will trip the system real quick. Not enough power to the AC and it trips.
depo is offline   Reply With Quote
Old 07-04-2012, 09:01 PM   #3
sherdep's Avatar
I have to agree with Depo -
Verify you have 30 amps with the correct polarity in the plug you are plugged into
Sounds more like an electrical problem more so then a clogged filter.
you can look at the filters and see if they have too much dust in them but I highly doubt a clogged filter is your issue.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-04-2012, 09:03 PM   #4
depo's Avatar
We tried last week to make a 20 AMP outlet support the AC with the adapter. It worked under 80 degrees Farenheit, once over 85 the draw was too high and popped the system.
Old 07-05-2012, 06:53 PM   #5
ejohnson03's Avatar
Kudos to my Forest River bretheren.
I opened up my Breaker Box in the garage and yanked out the punnie 15amp breaker and the accompanying 12ga wires.
Ran to the local big box store and purchased a 30amp breaker and some 8ga wire.
Promptly upgraded the Breaker Box with the bigger badder goodies, and through in a Hospital Grade Outlet for good measure.
WaaLaa... Got me some Cool breeze flowing in the Roo again.
Twas an impotant thing, my daughter and 4 grandkids from Texas are visiting for the summer.
Our humble ranch is about 900 sq.ft. So the Roo acts as our guest house.
Happy trails y'all...
See ya at Maumee Bay at the end of July, Higgins Lake South in August, and Pokagon in October.
Old 07-06-2012, 06:22 AM   #6
KyDan's Avatar
Awesome! I love a happy ending!
Thanks for the follow up.
Peace!
Dan & Rita D
Blue Ox WD hitch
breaker
