Old 12-08-2015, 06:16 PM   #1
space above fridge
I installed a surge protector and mounted the display above the fridge. when I cut into the panel I see all this unused room. This space also vents the fridge.
do you think its safe to make a cabinet for this space or should I seal it back up.
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 12-08-2015, 06:45 PM   #2
If you just block off from the back of the refrigerator box itself, NOT THE FINS, ETC. so the air can vent off the fins and coils, you should be ok to use that space as storage. I would suggest adding 2 computer fans at the bottom (just above the burner) that blow air up across all the tubing, fins, etc and out the top. If the outlet is on the side, fabricate a smooth alum sheet metal curve to direct the air out the side.
Old 12-08-2015, 06:49 PM   #3
MilCop4523's Avatar
not seeing what you see but if it was closed before you cut into it - one would think it would not harm the space if you made a cabinet. you could always design a small vent grate in the side if it was open before...
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 12-11-2015, 09:44 PM   #4
MNtraveler's Avatar
Check fridge installation specs for required clearance and ventilation.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
fridge
