Old 02-08-2012, 10:34 AM   #1
Spaceheater and extension cord.
I plan to run space heater from shore power with 25ft. -12gauge extension cord.Is that a problem?
If proper gauge and not very long,how is that different than the wiring in a house,except that it is exposed?
The Danish Guy is offline   Reply With Quote
Old 02-08-2012, 12:03 PM   #2
TURBS's Avatar
I would go with 10 ga imo ! But again that is just my opinion
Old 02-08-2012, 12:48 PM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
12 gauge wire is good to 20 amps Max load. Your heater most likely is 1500 Watts requiring a 15 amp circuit. You'll be fine with 12 Gauge wire.
More importantly - What are you plugging the 12 Gauge Cord into and what size wire is feeding that as well as the distance from the Electrical Panel to that receptacle?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-08-2012, 02:59 PM   #4
TURBS's Avatar
That's why I'm saying 10 gauge because of all the unknowns.
receptacle may have 14 ga wire running 30 feet to electrical box not only that but it could be spliced and junctioned 3 times before it gets there.
Old 02-08-2012, 03:07 PM   #5
I guess I will never know about the wiring to the plug.This is at a State Park.
I did not think that a bigger extension cord would help if there just isn't enough juice to the plug?
Old 02-08-2012, 03:21 PM   #6
TURBS's Avatar
Rv park shore power at the normal plug should be atleast 15 amp and then 12 gauge cord will be fine.
Old 02-08-2012, 03:37 PM   #7
X2 on using the 10 gauge wire!
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 02-08-2012, 04:27 PM   #8
jim44646's Avatar
No No No. You can't run a 10 guage wire off a 14 guage wire. 10 guage can handle more amperage than 14. you can can over load the 14 guage. 10 guage can handle 30 amps where 14 guage 15 amp.
Most parks are running larger guage so they can handle 50 amp survice.
jim44646 is offline   Reply With Quote
Old 02-08-2012, 06:32 PM   #9
Warrior's Avatar
I solved this problem by installing a dedicated circuit, with a 20 amp receptacle inside and a 12 ga. extension cord plugged in to the CG pedestal. I use this circuit primarily to power my 1500 watt heater and/or my auxiliary A/C unit. For all practical purposes I have upgraded my service from 30 amp to 50 amp.
Wayne & June Bowers Camp Mutts Bo & Baby
2011 F250 Lariat 4X4 SCSB 6.7 Power Stroke
50 Gallon Titan Fuel Tank
2011 Flagstaff 8528RLWS 5th Wheel
Reese Sidewinder Hitch 2002 Road Star Warrior
SouthWest Florida FROG
Warrior is offline   Reply With Quote
Old 02-08-2012, 11:57 PM   #10
Drinkin beer on the beach
Rod Johnson's Avatar
uhhh, the larger gauge extension isn't going to magically draw a bunch of current. The heater is going to draw what it wants, the larger extension cord will have less of a voltage drop, and the heater will probably pull LESS amps from the park outlet...
ETA, if it was a 50A service drop, the whole plug would be different, too.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
