If your stereo has a screen / menu, the front-rear fade will likely be hiding in the same set of menus as BASS, TREBLE, and BALANCE.
If those functions are knob-based then see if there is a dual-knob with markings like F-R (Front-Rear FADE), likely similar to another marking somewhere for L-R (Left-Right BALANCE.) Possibly, you might do something like push the volume for L-R and pull the volume for F-R.
If you can come up with make / model of the device in question, see if you can google search up a manual / user guide perhaps.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
