Old 12-26-2018, 12:55 PM   #1
BirdeeGirl's Avatar
Speakers not working
2018 31L5 with Pioneer sound system. Cockpit and outside speakers are on the same switch. Both have very low volume and a tinny sound. Living room speakers are fine. Any ideas? Iím thinking maybe a bad ground but would like to know if anyoneís had a similar problem and found a fix. Thanks
BirdeeGirl is offline   Reply With Quote
Old 12-26-2018, 01:36 PM   #2
Full-time 5'er
mnolasco's Avatar
My garage speakers and outside speakers are on different on-off switches but have the same volume control. I discovered that my outside speakers also had poor sound. I pulled off the wiring cover on the in side of the coach. i found that the factory had miswired the speakers. I switch the polarity on one of the speakers and everything was perfect.
The subwoofer on my soundbar was also not installed correctly by Forest River. I had to pull out the fireplace heater to access the cabinet and found that the passive radiator was mounted flushed up against the floor of the rig. I remounted the subwoofer so that air could pass freely around the cabinet and through the ports. After that the sound was much better.
Mike & Linda
2016 Thunderbolt XLR
Fifth Wheel Toy Hauler
2018 Harley Davidson Ultra Classic
mnolasco is offline   Reply With Quote
