Old 08-07-2013, 01:52 PM   #1
Pop
Pop's Avatar
Splendide 2100xc Vented Dryer in a 320RS
I have purchased a new Vented Washer/Dryer for my 320. There is a Sticker on the side wall of the closet that says "Dryer Vent Location". Has anyone installed one of these vents. I was wondering if there is anything unusual, that I may run into, or any advice that someone that has completed it, may have run into.
Pop is offline   Reply With Quote
Old 08-08-2013, 07:53 AM   #2
Patrickdana's Avatar
I installed one. The location is close to a stud. If you vary the location be careful or you will have a stud where you cut the hole. Use a stud finder.
For God hath not given us the spirit of fear; but of power, and of love, and of a sound mind. 2Timothy 1:7
Patrickdana is offline   Reply With Quote
Old 08-08-2013, 09:17 AM   #3
Pop
Pop's Avatar
Thanks. I located the studs, last night. Was concerned with the Electrical Outlet, so close, if there was wiring running in the wall. Did you find this to be a problem?
Old 08-08-2013, 06:22 PM   #4
Electrical wire is loose. I cut small hole with drywall saw then expanded it to fit remodel electrical box
Old 08-09-2013, 02:57 PM   #5
Pop
Pop's Avatar
Thanks. I'll give it a try.
I appreciate you sharing your experience.
