Originally Posted by SixSigmaGuy
Hi, I just bought my washer dryer few weeks ago have installed it. I did a couple of test loads before installing it to verify that everything was working, and after installing I started a small load with no detergent. How about 30 minutes into the cycle, it just stopped. There are no lights on the panel, and pressing the on-off button does nothing. I have confirmed that I am plugged into a socket that has power. Is there some kind of fuse, or breaker, in the washer set might have flipped that I can reset?
Can I ask what you specifically mean, when you say plugged into a socket that has power.
Are you referring to the RV is plugged into shore power..... or the washer/dryer is plugged into a socket INSIDE the RV that has power?
If just the RV is plugged into shore power, it could be as simple as you tripped a circuit breaker in the RV's electrical distribution panel to that washer/dryer circuit.
