Old 08-13-2019, 09:45 PM   #1
dbledan's Avatar
Squeaky bathroom fan
I have one of these and we are happy with it but it has started to squeak a bit when running at higher speeds. Can I put some lubricant on it or will this make things worse?
Looking for a lubricant suggestion as I dont want to replace the fan if I dont have to.Click image for larger version
dbledan is offline   Reply With Quote
Old 08-14-2019, 08:10 AM   #2
Looking for a lubricant suggestion as I dont want to replace the fan if I dont have to.Attachment 212325
Sure, drop some oil in the bearings if you can get to it. I had a hot water tank with a squealing/slow exhaust fan bearing that caused the hot water tank to throw fault codes and shut down. I oiled it monthly with a syringe and got 4 more years out of it.
I would remove power from it and use a small steel syringe to drop oil on the shaft just beside the bearing and the sides of the races as I manually spun the fan. I would do this to both bearings each time. The fan would then run silent and fast like normal for a month or so. Eventually the tank rotted out and I replaced it with that still bad bearing that tried to freeze up every 4-6 weeks.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 08-14-2019, 08:19 AM   #3
You are likely going to need to get to the shaft of the motor to lube it.
That may/may not require some disassembly but as mentioned, a drop of oil in the bearing(s) (usually brass) often cures a squeaky/slow running fan.
I've done this to heater fans, regular fans and all kinds of motors.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 08-15-2019, 11:31 PM   #4
dbledan's Avatar
Thanks! Any specific type of oil you suggest?
Old 08-16-2019, 08:52 AM   #5
Any good automotive motor oil or general household oil like 3 in 1.
WD-40 is not an oil.
bathroom, fan, roo
