Old 03-08-2015, 09:15 AM   #1
Squeaky Microwave / Convection Oven
When driving my Sunseeker MB2400R down the road my Microwave/Convection Oven is the only item in the RV that squeaks and rattles on the trip and frankly, it is starting to drive me crazy. Is there a way to support it in a fashion that secures it more to the unit? I was thinking more support with wood or metal brackets? But then I started to think that since it is a convection oven it may need some space around it due to the heat it may create? Any ideas or ave others found a solution? I would like to have a solution for my dealer before I take it in (or maybe I can DIY the problem .. but the unit is under warranty) ... and BTW it is not caused by the glass dish :-) I solved that rattle and it squeaks with the dish out of the unit.
oregonct is offline   Reply With Quote
Old 03-08-2015, 09:17 AM   #2
Could the rattle possibly be the turntable platter inside?
Old 03-08-2015, 09:23 AM   #3
You need to explain how it is attached to your unit first. It is always the connection points first, then the close clearence points. Remove it, inspecting for; loose mounting screws, rub marks where it resides. Then address those issues with several anti-squeek methods.
