Old 08-06-2012, 03:02 PM   #1
wyo700's Avatar
Starting fridge with TT leaning
When my TT is parked at my house it leans to the passenger side and my fridge is on the opposite side. Is it ok to start my fridge to get cold before we go with it at a lean like this? Thanks.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 08-06-2012, 03:09 PM   #2
oldprof1's Avatar
If the lean isn't too bad. These fridges are an ammonia evaporative system. If the angle is too great the tube containing the ammonia will over heat and possibly ruin your $1200 fridge. LEVEL the trailer then fire up the fridge, no problem!
oldprof1 is offline   Reply With Quote
Old 08-06-2012, 03:15 PM   #3
papap's Avatar
as long as fridg is on side wall and camper is level front to back. you should be fine.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-06-2012, 03:15 PM   #4
wyo700's Avatar
It's not terribly bad I will take a pic later and post.
2013 Toyota Tundra
Old 08-07-2012, 06:56 AM   #5
Herk7769's Avatar
I agree with Papap (who doesn't really?).
The critical factor is along the BACK of the fridge where the bends in the pipes are located. Left to Right will not be a problem (though I would definitely level L/R to protect the slide out motors) for a fridge mounted so that the back of the fridge aligns front to back of the camper.
If your fridge is mounted on the rear wall or front wall, then side to side is the critical direction.
Name:	RV evaporative Fridge.jpg
ID:	17629   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-07-2012, 07:24 AM   #6
KyDan's Avatar
"Not too bad" doesn't give us much information.
My home parking spot is also out of level side to side.
I'll guess it's maybe 1 to 2 inches lower on one side.
Probably closer to 1.
EDIT- on 2nd thought it's probably 1 or less.
I once put a "1 by" under the low side and it was too much.
I leave it parked with the tongue low so it will drain better but
when we're going to turn on the fridge for packing I crank it
back up level front to back.
It's 4 years old and has been pre-cooled dozens of times so I guess
it's OK.
Peace!
Dan & Rita D
KyDan is online now   Reply With Quote
Old 08-07-2012, 07:26 AM   #7
Can you not put boards under the passenger side and level it? Solves the problem real easy. Best boards are the composite deck boards, won't rot. Pricey, but durable.
Old 08-07-2012, 07:54 AM   #8
wyo700's Avatar
Here is how it sits left to right. It's just a little low in the front.
2013 Toyota Tundra
Old 08-07-2012, 07:56 AM   #9
wyo700's Avatar
Yes I can probably put a couple 4x4 under the one side probably what I will do before I start it up
2013 Toyota Tundra
Old 08-07-2012, 07:59 AM   #10
papap's Avatar
Just pour some concrete and level it off. LOL
Old 08-07-2012, 08:00 AM   #11
Looks like a little creative digging could solve a lot of your problems. Maybe a level groove for both sides which would lower the axles and at the same time raise the front. Make a "landing pad".
Old 08-07-2012, 08:14 AM   #12
wyo700's Avatar
That's the next plan
2013 Toyota Tundra
Old 08-07-2012, 08:53 AM   #13
Herk7769's Avatar
I bought 2 12 inch square pavers for my low side and park the camper on it to make it side to side level.
It REALLY helped with my backing skills trying to hit those 12 inch blocks centered.
I ALWAYS level front to back even when parked (OK, maybe a tad tail low to aid in dumping my tanks in the lawn sewer vent. )
Old 07-11-2023, 11:14 AM   #14
Until you pour a pad, put some pavers or use treated 2x8's to get the tires up off the dirt. This will save your tires from being damaged by setting on the ground which allows moisture damaging your tires from prolonged storage.
BrianRR is offline   Reply With Quote
Old 07-11-2023, 11:31 AM   #15
Do you have links or references that describe how or confirm that water damages rubber tires? I’ve never heard of this.
Anyway, the thread/last comment was about 11 years old.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
