Old 03-30-2013, 07:29 PM   #1
Toad Haul's Avatar
Startup of Furnace
I've got a new RLT1905 TT and have a question on my furnace. We are getting ready to go out on our maiden voyage and I have a couple of questions. First of all, how do I start the furnace? I've got lots of documentation with the camper to install a furnace, but nothing on actually using it. So, here is what I "think" works...
Once I'm parked, leveled, etc...
1. Turn on my propane
2. Close my Interior Power circuit breaker.
3. Set the thermostat to desired temperature
4. Furnace will auto-ignite and run
Yes? No?
Assuming this is remotely accurate, does my camper need to be hooked to a power source (110vAC) to work? Can I run my furnace on battery power?
This is likely pretty simple stuff, but like I said..our dealer walk-thru was done by a mechanic who was pretty put out.... Any help out there?
Toad Haul is offline   Reply With Quote
Old 03-30-2013, 07:44 PM   #2
Dave_Monica's Avatar
There may be a selector on the thermostat for heat/off/cool as it controls both the furnace and the AC. There also may be a fan selector for on/auto...is should be on auto.
The ignition and furnace fan are 12V.
Dave
Old 03-30-2013, 07:47 PM   #3
bikendan's Avatar
be sure to let the furnace run for awhile, with windows, vents and door open. to burn off the factory oils/residue.
someone else here just posted about the alarms going off because the dealer didn't do it for them, nor told them that they would need to do it.
by the way, what brand is your RLT and what is an "Interior Power circuit breaker"?
are you talking about the regular breaker for the furnace?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-30-2013, 07:51 PM   #4
Toad Haul's Avatar
Out RLT is a Forest River Mini Lite model. I wasn't certain if the heater blower would run on 12v and was wanting to test it before we hit the road. The alarm unit in the trailer does keep going off now and of course, they didn't tell me at hing about that...
Old 03-30-2013, 08:01 PM   #5
Herk7769's Avatar
Make sure WHICH alarm is going off.
The CO or Propane alarm should not be going off for a heater burn off.
Low house battery power will set off the propane detector.
HAM CALLSIGN - KC3FFW
Old 03-30-2013, 08:04 PM   #6
Broadway Joe's Avatar
If it hasn't run before, you might have to try several times before propane reaches the heater. If it doesn't start by the third attempt, it will lock out. You have to shut off and retry to reset the lock-out.
HTH
Broadway Joe is offline   Reply With Quote
Old 03-31-2013, 07:18 AM   #7
Toad Haul's Avatar
Thanks everyone for the help. The alarm that keeps going off is on my Power Inverter unit. No idea what is causing it to alarm.
I'll try to burn in the furnace today and see how it goes.
Old 03-31-2013, 07:38 AM   #8
Engineer of Crazy Train
ChooChooMan74's Avatar
Just to throw one out there, you do have a battery installed, right?
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-02-2013, 07:06 AM   #9
Herk7769's Avatar
Inverter alarms are typically "Low Battery" alerts.
