Originally Posted by RiderBloke
Plug in a triple jack to RCA lead; ignore yellow RCA (video); plus two RCA joiners connecting a second cable RCA to normal 8m jack for iPad etc. That will work if anything will.
(Problem with a normal plug in a triple jack is one channel of audio is often connected to video part of jack.)
I have the bits here but I’m not there to try it out. [emoji51]
Attachment 169940
Some of the other solutions here will not work if the input into the radio is an AV i/p. The cable you have is OK but will look a bit messy, which is OK, my place is full of such things, albeit hidden behind stuff. For a more 'elegant' solution try this. The 3.5mm jack end is what plugs into the radio, the other end with the RCA's has to be modified. This requires you to cut off the RCA plugs and join/solder some wires on to another 3.5mm jack plug.
For starters you cut-off/tape up/ignore the yellow video connector, this is not used. What you want is to cut off the red and black connectors and solder their wires to a new 3.5mm stereo jack plug.
When you cut off the RCA ends, strip the wire back (about 2-3 inches should be enough), you will see an insulated wire core covered with a shield. Join the two shield wires together by twisting. These will be soldered onto the ground/neg pin on the jack plug.The positive/centre/insulated wire of the red wire is soldered onto one of the centre/tip lugs and the insulated wire of the black wire is soldered onto the other ring point.
I hope this makes sense to you. This is fiddly stuff and if you haven't done it before will probably tax your skill levels and patience.
Here is a link to a video that might help.
