Old 04-06-2012, 06:56 PM   #21
I have a 31 RETS and as far as I can tell the SUB is under the stairs to the bedroom!
Does any one know a way to access this area, ideally with a tool no larger than a screwdriver?
Wooly
2010 Sabre 31RETS-6
2007 Sierra 2500HD Duramax
Reese 18K Signature Series
wooly is offline   Reply With Quote
Old 04-06-2012, 08:15 PM   #22
TURBS's Avatar
wooly since your unit it is similar to mine I have not found a way to it yet .
the panel in the basement looks to be glued to the frame work .
I dont see any screws .
Old 04-06-2012, 08:31 PM   #23
hotrodj125's Avatar
I haven't found my sub-woofer yet,(in a 320RS), and it wasn't hooked up to the TV, had to go buy a fiber-optic cable to get it to work- can believe Foret River didn't hook this up.
hotrodj125 is offline   Reply With Quote
Old 04-07-2012, 03:45 PM   #24
I am beginning to think that the stairs may lift out. The way that the carpet is installed and the fact that I can slide a blade under, down the sides and down the back of them makes me think there are a couple of well placed screws somewhere!!
2010 Sabre 31RETS-6
Old 05-05-2013, 09:06 AM   #25
Our sub is not working at at all. Found loose wire, but it still does not work. Even measured to wire from the stereo and it is reading zero volts.Must be the Concertone.
Had to fix 90% of the speaker wires too, wrong polarity. Sounds way better but with no bass from the sound it sounds pretty tinny.
Ajc71 is offline   Reply With Quote
concertone, stereo, subwoofer
