Forest River Forums
Sunline User Photos
Old 06-07-2011, 08:17 AM   #1
Lightbulb Stereo Sub-woofer
This isn't really a Concertone issue, but probably more of an issue brought on by Forest River. But I thought I'd post here since it is an entertainment issue. I was wondering if anyone else has this same setup. We have a 2010 Rockwood 2701SS. When they (whoever 'they' might be) installed the sub-woofer it was installed it in a storage space in what I will call the entertainment center, behind a solid wood panel that matches the other cabinet doors. When watching a movie or listening to the radio in general, nothing can be heard from the sub-woofer with this panel in place. If I remove the panel to expose the speaker, then I can hear it and it sounds pretty good.
My first question is, is this the standard location for others or is just where, and how, they decided to install it in mine?
Second, I'm thinking of two options in order to get more sound from this speaker for a better overall 'entertainment' experience. I'm thinking of either removing the center of the solid wood panel and installing a grill thereby allowing it to be heard (knowing that sub-woofers are more about being felt and not necessarily heard). This would be the easiest fix since it would not require moving and rewiring anything. But moving it would open up more storage space. My other idea is to move the speaker box from this cabinet and attaching it to the underside of the couch. Of course this would require rewiring it and I haven't looked into just how much trouble that would entail. But there is plenty of unused space below the couch AND when sitting on the couch while watching a movie, it would give you more 'feel' from the speaker! I could also turn it on in the morning to BoUnCe my kids out of bed in the morning
Just thought that I'd get an idea as to whether this is a typical setup and whether anyone has done a modification for their sub-woofer.
Larry
2004 Toyota Tundra Double Cab
Killman is offline   Reply With Quote
Old 06-07-2011, 08:29 AM   #2
Good morning: My sub woofer came from mfg. behind a wall but they had cut out and put a grill in front of it. I guess for you the installer just got lazy!.
Wilkrich is online now   Reply With Quote
Old 06-07-2011, 08:33 AM   #3
Rugged Brown's Avatar
I must have 'lucked out' and got the same 'lazy installer'.
Terry/Bernadette
Lily the Yorkie
2010 RAM
2011 Flagstaff 8528 CKWS
Rugged Brown is offline   Reply With Quote
Old 06-07-2011, 09:00 AM   #4
Mine has a grill in front of it too.
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 06-07-2011, 09:18 AM   #5
Grumpy Old Member
ChrisZazzara's Avatar
My subwoofer is also installed in a cabinet space below the entertainment system but the cabinet has been cut out to include a grill assembly.
Chris Zazzara
2012 Windjammer 2008w
2010 Dodge RAM 1500
Reese Dual Cam WDH
ChrisZazzara is offline   Reply With Quote
Old 06-07-2011, 09:43 AM   #6
At least it sounds like I wasn't the only one! Even so, I still love my camper and in any event, I can probably do a better job of installing a grill myself! I do agree that quality control by whoever installed the entertainment system was subpar. On ours, they didn't get the head unit centered in the space, nor the XM radio port. And the front right speaker was installed about a foot further to the front of the camper than the right front speaker. Almost to the point that it interferes with the curtain on the left side of the entertainment console. That, unfortunately, will be much more difficult to fix since holes are cut and drilled into the ceiling for the installation of the speakers. I do plan on one day re-centering the head unit and XM port, but I will need to find out how to order some of the same paneling used in the trailer.
Larry
Old 06-07-2011, 09:49 AM   #7
Forest River Class C's
A subwoofer shouldn't need to be exposed to function. It's bass...in many cars you put it in the trunk. That's weird.
bclemens is online now   Reply With Quote
Old 06-07-2011, 10:28 AM   #8
Grumpy Old Member
Well, these are crappy subs at best and they should be able to move some air around to do their job. I'm not privy to the crossover frequencies involved here but I'd be willing to bet that Concertone is asking the sub to carry a bit more than just low base considering the size and build quality of the ceiling speakers.
Please don't read this as a complaint. I'm very happy with the abilities and quality of the AV system in the camper. It works, sounds ok, and is feature rich.
Above all else, remember we're here to
Chris Zazzara
2010 Dodge RAM 1500
Reese Dual Cam WDH
Old 06-07-2011, 10:30 AM   #9
Location: Jacksonville Florida - Home of the Jaguars !!!!
Have you tried adjusting the sound settings on the Concertone? Mine is behind a screwed shut cabinet door w/ no grille as well, but I can hear it pretty good when I adjust the bass settings on the radio. No, it's not ground pounding bass, but it is sufficient for what it is. At least it is to us, anyway. Installing a grill on there would help some, though. I considered that at first, too. Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 06-07-2011, 11:12 AM   #10
I have adjusted the bass settings at the radio and it made a little difference, honestly not that much in my opinion. I don't expect movie theatre, or even home theatre, quality sound....I'm roughing it after all !! But if I paid for something, and it is taking up space and weight, I'd like to be able to utilize it to the best of its ability. I think adding a grill to the panel is probably the way to go, although I'd like to be able to use that space as storage. But not at the expense of taking the camper apart to run wires to a different location.
Larry
concertone, stereo, subwoofer
» Online Users: 619
151 members and 468 guests
1l243, 4bnabird, 87CrewDually, alphadog99, alpinemike, autorot8, baldy, Bchecker, bclemens, Big Dawg, Big Vic, BigDogD, bka4tcu, bouldercamper, buzzmonster, bwhunter65, camper1999, camping4us, Capsfloyd, capucine, case1175, Catman86, cbconway, ChiefGeek, chiro, Chrylser_91, cpaulsen, CRZ, dansa122, daveinpickerington, davidjb, ddemme, dec1952, DGrissom, Dhudglr, digger47, djorgensen3, dman114, donh, Douglasdh62, dunnnc, Earth Station, Falcon35, feerobk, Filthy Beast, Fire Instructor, frankt, FreedomTracker, gamller36, geo, Great Horned Owl, Greywolfmn, Happy Vibe, harleyvette, hokiecampers, House97, JamesR, Janet H, jar3316, Jeep4Two, JeffK, jfischer, joelabq, jojo bamboo, judy3972, kanati, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, kozzy, Labzy, Larryvsr, LauraW, leennp, lesameinze, LFugate, lindy, LKicklight, lochsa, Lonewolfcry, Marsarch, melbornj, MikeFletcher24, missy9249, Moracechaney, Mountainmanbob, mraynie, mtnguy, myredracer, nailit, ncgrl1, NeilM108, NorminN.B., OregonCamper, Papa Roo, pappcam, patmo2000, Pinesman, Poppy Bill, punkaccountant, rawlus, rerger, RGH, rjshiflet, rob2112, ROCKIN 34, rockin'ray, ronhanson, rotorhead1250, sandys, scorekeeper81, SDENN4281, Selib1, sherri330, silverwing, Snowsail, softwarejoe, sprayking, steeljag, Stevea1956, Superchief, tblkfsh, Tee, tentcamper1, thehamguy1, thumper, Titleguy, tls5150, tmmar, Tom47, tonybab, Tracer, Traci, trailertrash78, travyp, Triguy, T_LMurphy, u0179187, unhcharger25, Unruly, venturetaz, Vette4trcr, VRMHW-M, VTX Al, wfmdfm, Wildcat Chris, Wilkrich, windrider, yworrydog
Most users ever online was 996, Today at 11:04 AM.
Close [X]
