Old 09-19-2013, 06:13 PM   #1
Stereo system
Have a 2011 Windjammer TT. One night during a rainstorm the stereo lit up and I couldn't get it to turn off. Pulled it out and found out I had a leak from the satellite radio antennae. Fixed the leak and plugged everything back in and everything works BUT the whole thing is lit up and I cannot get the lights to turn off. Any ideas?
Name:	2013-09-19 18.09.06.jpg
Boomerang56 is offline   Reply With Quote
Old 09-19-2013, 06:47 PM   #2
What make/model is the beast? Sometimes they have separate wiring for the lights (like in a car) and maybe it's started "working".
Old 09-19-2013, 06:55 PM   #3
I have looked all over the 'beast' and in all of my paperwork and cannot find a name. The "quick start guide" has a form number of CT-QS-4 100208 and it has a serial number but no names
Old 09-19-2013, 07:22 PM   #4
TURBS's Avatar
Its a concertone I have the same one.
Have you tried pulling the fuse and then re installing?
Turbs
Old 09-19-2013, 07:56 PM   #5
It is a Concertone zx690 or zx700 (identical models). You can pull the fuse which supplies 12v power in your unit (located in panel where your circuit breakers are).
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-19-2013, 08:51 PM   #6
Pulled the fuse from the back of the box and the one in the fuse box under refrigerator...neither helped.
Old 09-21-2013, 11:10 AM   #7
Similar incident: rain water came down through antenna wire from roof and dribbled into the unit. I fixed the leak and left the unit out of wall to let everything dry out. It took a few days, but it eventually it started working normally.
2015 Rockwood A128S
2010 Rockwood 2604
Old 09-21-2013, 12:01 PM   #8
I was pleased that everything still worked. Prior to the leak messing it up, I wondered why it would have a clock if you couldn't read it unless the unit was turned on. Now all of the lights stay on even when the unit is off. I guess I need to find someone that understands the wiring...for now I just take the fuse out under the refrigerator and will put it back in when I want to use the unit. At least this way the whole room is not constantly lit up with blue lights. Thank you all for your comments and suggestions.
