Old 08-29-2012, 08:47 AM   #1
MaD
stove hood fan
my stove hood fan stopped working. I took it out and it works if i bypass the resister (or whatever it's called) on the white wire.
Is this required? Or do i need to find a replacement for that thing?
MaD is offline   Reply With Quote
Old 08-29-2012, 09:31 AM   #2
I'd be replacing it. Using the gas stovetop in a small confined space without an exhaust fan sounds dangerous to me.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-29-2012, 09:46 AM   #3
X2 on the cooking in a camper without the exhaust fan running.
How about a picture, mine does not have the (whatever it's called). You might see if the motor gets hot by running it without that thing. If it doesn't, just try it that way and keep a close watch on it.
Old 08-29-2012, 10:06 AM   #4
I can only take a guess here. The white may be a thermistor. Since it is in series, I can't imagine it being a fuse. A thermistor, has a given resistance for a given temp. As the temp goes up, the resistance goes down. This would keep the fan at a slightly lower speed, when first turned on, but if heat built up, would slowly increase the fan speed.
I don't know this for sure, just a guess, and about the only thing that makes sense to me anyway.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-29-2012, 10:27 AM   #5
MaD
I just had a closer look and in very small letters it says "sefuse 15a" so i guess it's a fuse. Might have a hard time finding one like that.
Name:	2012-08-29 12.23.39.jpg
Old 08-29-2012, 10:39 AM   #6
You can get replacement fuses and fuse holders at any auto parts stores.
Personally think 15a is a little high for a fan motor. Maybe 7.5 or 10 max.
Old 08-29-2012, 10:39 AM   #7
TURBS's Avatar
Radio shack .
Old 08-29-2012, 10:46 AM   #8
I would convert to replaceable auto style, or something easier to find. May still have a fan problem, something caused it to blow.
LadyWindrider
Old 08-29-2012, 11:12 AM   #9
Road-King's Avatar
Just did a Google on that sefuse. It seems to be a Thermal Fuse. Cuts the power when the ambient temp gets to specified point...
Found this on eBay may be what you need...
5 PCS NEC SEFUSE Cutoffs SF240E Thermal Fuse 240 C 15A 250V on eBay!
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-29-2012, 11:21 AM   #10
Not being an electrical guru, I would replace it with an automotive fuse and holder.
fan
