Old 09-05-2014, 11:52 AM   #1
Stove top cover....
We've been shopping around (online and in stores) for a suitable stove top cover that will also serve as additional counter space when not actually cooking. We've looked at Polyethylene, and are considering Corian. The problem is the cost!!....Where can one find a reasonable priced 24x24 in Sq by 1/2 inch thick piece of suitable material??
louiejo is offline   Reply With Quote
Old 09-05-2014, 11:57 AM   #2
My cousin uses a cutting board like this.
http://www.amazon.com/Camco-43753-Ha.../dp/B000EDOT8C
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-05-2014, 03:00 PM   #3
If you're the least bit handy you could make one from plywood stained to match existing wood work..
Old 09-05-2014, 03:49 PM   #4
I have one that is almost exactly like Wiscampsin has. Took some measurements, cut the wood and lacquered it. I used wood glue to keep it together.
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 09-06-2014, 12:49 AM   #5
Sturgie's Avatar
Used a cutting board I had in the house, but sure a new one would've looked better. Used beveled stainless steel machine screws and plastic spacers to level and prevent sliding. Got those from Home Depot from the hardware section Click image for larger version
Name:	ImageUploadedByForest River Forums1409982499.801781.jpg
ID:	62189Click image for larger version
Name:	ImageUploadedByForest River Forums1409982533.602423.jpg
Sturgie is offline   Reply With Quote
Old 09-06-2014, 06:55 AM   #6
cpaulsen's Avatar
Attachment 62155
Looks almost exactly what I did....solved any problems I had.
cpaulsen is offline   Reply With Quote
Old 09-12-2014, 11:53 AM   #7
Stove top follow up
So after much online shopping and price comparison, we decided to use Corian for a stove top. We called one of our local retailers in Vancouver, WA (Solid Solutions) and he sold us a 26"X 32" remnant off his shelf for $40. I had to also get a $20 fine toothed carbide tipped blade to get a fine cut on the Corian and some 1/8" thick crafts foam pads at Joanns. After cutting the piece to our exact specifications, I sanded the edges and corners to a rounded edge and spray glued the foam to the back of the Corian and ....Voila!!! new counter top that matches our original equipment and looks good!!!......the time and work was well worth it, we got what we wanted and are happy with the results.....
ID:	62652   Click image for larger version
ID:	62653   Click image for larger version
ID:	62654   Click image for larger version
Old 09-12-2014, 02:21 PM   #8
Jimandchris's Avatar
Looks nice!
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 09-12-2014, 02:37 PM   #9
grhodes50's Avatar
Or you could try this.
All in one range cover, cutting board and counter top.
Kitchen Range Cover
Gary & Trish
2019 Nights Camped - 3
cover
