Old 02-04-2013, 04:56 AM   #11
Thanks, Jim. I didn't realize the the blower is always running on 12V. Is there a fuse in or under the unit? Because none are blown on the breaker/fuse panel.
antsing is offline   Reply With Quote
Old 02-04-2013, 05:40 AM   #12
Commercial Member
huntr70's Avatar
If the blower stopped when you lost shore power, you probably have a dead battery.
Pull it out, and charge it. The blower won't work if there is low 12 volt voltage.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 02-04-2013, 02:46 PM   #13
You said "breakers" those are 110 volt . You may have a 110 volt breaker partially off , try flipping all of the 110 volt breakers hard to off then flip them back on . Just to be clear are you also checking your automobile type 12 volt fuses ? Jim
FarmerJim is offline   Reply With Quote
Old 02-04-2013, 03:00 PM   #14
Yes, all fuses are good and I reset all breakers. Just took it back to the dealer and it looks like a failed blower motor. Thanks for all the tips!
Old 02-04-2013, 04:36 PM   #15
Glad your dealer is taking care of this . Please update us on what was the cause and the fix as we all learn from this forum ! Jim
Old 02-04-2013, 05:10 PM   #16
Great, that is what I am looking at too then .. at least It is very strong indication of the problem as they failed he same way.
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 02-06-2013, 07:58 PM   #17
Well, I just picked up the Roo from the dealer. During troubleshooting, they were not able to get the blower to work. So the removed the furnace and hooked it up to 12V and gas on the repair bench. After pulling it apart, they determined the sail switch was stuck. Switch was adjusted and several optests were satisfactory. Upon reinstallation, no further issues were found and the unit works properly. I will run it this weekend to make sure.
Thanks to all for sharing your insight and experience.
2013 roo 183
