Old 06-09-2010, 09:32 PM   #1
Suburban Furnace problem
I Suburban SF20 furnace is not working. I have a 2009 F/R Surveyor 235RKS. If I click it on, the blower starts for 20 seconds and shuts off. I am not hearing any clicking from the ingiter or smelling any propane. Any ideas? Any help would be appreciated.
smib is offline   Reply With Quote
Old 06-09-2010, 10:33 PM   #2
NWJeeper's Avatar
Sounds like a bad sail switch. The sail switch senses that the fan is running, if it isn't then it shuts down before opening the propane valve. Find the sail switch, bypass it with a jumper and see if it will run though the entire startup process. If it does then the sail switch is bad.
The caveat with this is that you have shore power plugged in or you are sure you have good batteries. Not enough amperage will cause the fan to turn to slowly to close the sail switch.
Ed & Wendy
www.nwjeepn.com
Old 06-10-2010, 06:33 AM   #3
yvesm's Avatar
If you have a bas board replace it from these guys. Less money and better quality. Dinosaur Electronics Home. High quality circuit boards for RV appliances.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 06-10-2010, 06:43 PM   #4
So, exactly where is the sail switch located? I have not removed the furnace yet. It looks a little complicated but I may have to remove the units.
Old 06-10-2010, 07:43 PM   #5
NWJeeper's Avatar
If you bought your rig new you should have received a manual for the furnace which shows a parts breakdown. If not you can ask for one from a Suburban repair facility. You can also refer to this Furnace Information document put out by Suburban.
If you have an access door on the outside of your RV to the furnace you may not even need to remove it to work on it. This is the way it was on our older Fleetwood motorhome we used to own.
Ed & Wendy
www.nwjeepn.com
