Old 09-08-2016, 01:24 PM   #11
Head Rambler
Good luck. They don't give you much room in those things and you don't want to pull it out unless you have to.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-08-2016, 08:46 PM   #12
Hi, I tried to get at the wires for the blower but as I was doing this I touched the time delay relay for the ignitor for the burner and it fell off the module board. So it appears that I need a new board. For what it is worth the blower fan does move freely in the housing. By the way the board is not fastened very well to the furnace it just slides on to the side. For something so vital to the operation of the furnace it just hangs there.
gregk is offline   Reply With Quote
Old 09-08-2016, 09:15 PM   #13
crunchman12001's Avatar
Don't overlook the obvious, is your battery charged? You need 12v for ignition. Also, is your propane full and turned on?
What year is your model?
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
crunchman12001 is online now   Reply With Quote
Old 09-09-2016, 08:30 AM   #14
Hi, Battery is charges and I am plugged in to a 120volt AC power supply, propane is turned on and full. The trailer is a 2012 Wildwood X-Lite and the model of the Furnace is a Suburban SF-30FQ.
Old 09-09-2016, 08:55 AM   #15
Flybob's Avatar
There is a safety feature built into the furnace that will prevent it from starting if it has had several failed starts. Remove the fuse for the furnace to completely disconnect power. Let it sit for a few minutes then reinsert the fuse and try again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-09-2016, 07:12 PM   #16
Head Rambler
Bummer about the relay falling off the board.
You should look at the Dinosaur replacement boards for that furnace.
Gotta go campin!
Old 09-13-2016, 10:24 AM   #17
Hi, I have taken the fuse out and replaced it with a new one with the same results. As I said before the time delay relay separated from my circuit board. I am looking for one online but I not sure of the model # associated with the circuit board. I know the model and serial # for the furnace itself but not sure if a separate # exists for the board. If someone could give this information it help in the online search for a board that is compatible with my furnace. Thanks.
Old 09-13-2016, 10:53 AM   #18
Left Coast
All you need is model number....serial number maybe...The new board I put in mine was different shaped then the original, but they used a cross reference to send me the correct one
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 09-13-2016, 01:24 PM   #19
Head Rambler
Just call or email Dinosaur and they'll get you the right one.
Gotta go campin!
furnace, suburban
