09-06-2016, 11:53 AM
Suburban furnace will not operate.
Hi, I have a Wildwood X-lite 28' travel trailer and I am recently having problems with the propane furnace. It is a Suburban SF-30FQ S/N 134403003 furnace that will not start. The thermostat is a Dometic single zone LCD that runs both the furnace and A/C. When I turn the thermostat on to furnace I can a click in the Roof top A/C unit and in the furnace as well. Power seems to be getting to the furnace but does not go to the blower or ignition. Any help would be appreciated. Thanks.
09-06-2016, 03:12 PM
Has the furnace ever worked?
have you checked the fuses?
How did you determine that power 'seems' to be going to the furnace?
If it's never worked it could be that the switch in the furnace is off.
Gotta go campin!
09-06-2016, 06:20 PM
Hi, The furnace worked fine last month and I did check the fuse which was fine. When I was checking for power around the switch at the furnace I accidentally crossed 2 wires which blew the fuse. So power is getting to the furnace.
09-06-2016, 06:33 PM
Did you connect the thermostat wires together to see if that would run it?
Gotta go campin!
09-06-2016, 07:46 PM
No I did not try this. Just tie together the 2 thermostat wires from the furnace. They are the smaller wires (I believe blue in colour) will this make it run all the time and will it ignite the burner?
09-06-2016, 07:57 PM
Cyber Phrenologist
I love furnace threads as mine has NEVER worked right. Carry on!
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
09-07-2016, 09:43 AM
Yes they are blue. All the control board in the A/C does is connect them together thru a relay to get the furnace to run.
Gotta go campin!
09-07-2016, 05:43 PM
Hi, I tied the thermostat wires together with the same result. All I here is a click but nothing. At least we can rule out the thermostat.
09-08-2016, 10:18 AM
That's what I was going for. Seeing if it was the furnace or the thermostat.
Now that you've narrowed it to the furnace, you can concentrate on that.
Since you're hearing a click it's getting power to the time delay relay. I assume that's what you hear clicking. But the blower motor isn't running, right?
If you can access the blower motor, I'd hook 12 volts to it directly and see if it runs. If it does, then it leads to the relay/control board.
Gotta go campin!
09-08-2016, 11:28 AM
Yes, the clicking sound is the time delay relay on the circuit board getting power. The blower did not come on at anytime (even when I bypassed the thermostat). I will see if I can access the blower wires and try that. Not much room to work in.
09-08-2016, 12:24 PM
Good luck. They don't give you much room in those things and you don't want to pull it out unless you have to.
Gotta go campin!
09-08-2016, 07:46 PM
Hi, I tried to get at the wires for the blower but as I was doing this I touched the time delay relay for the ignitor for the burner and it fell off the module board. So it appears that I need a new board. For what it is worth the blower fan does move freely in the housing. By the way the board is not fastened very well to the furnace it just slides on to the side. For something so vital to the operation of the furnace it just hangs there.
09-08-2016, 08:15 PM
Don't overlook the obvious, is your battery charged? You need 12v for ignition. Also, is your propane full and turned on?
What year is your model?
2015 F-250 FX4
09-09-2016, 07:30 AM
Hi, Battery is charges and I am plugged in to a 120volt AC power supply, propane is turned on and full. The trailer is a 2012 Wildwood X-Lite and the model of the Furnace is a Suburban SF-30FQ.
09-09-2016, 07:55 AM
There is a safety feature built into the furnace that will prevent it from starting if it has had several failed starts. Remove the fuse for the furnace to completely disconnect power. Let it sit for a few minutes then reinsert the fuse and try again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-09-2016, 06:12 PM
Bummer about the relay falling off the board.
You should look at the Dinosaur replacement boards for that furnace.
Gotta go campin!
09-13-2016, 09:24 AM
Hi, I have taken the fuse out and replaced it with a new one with the same results. As I said before the time delay relay separated from my circuit board. I am looking for one online but I not sure of the model # associated with the circuit board. I know the model and serial # for the furnace itself but not sure if a separate # exists for the board. If someone could give this information it help in the online search for a board that is compatible with my furnace. Thanks.
09-13-2016, 09:53 AM
Left Coast
All you need is model number....serial number maybe...The new board I put in mine was different shaped then the original, but they used a cross reference to send me the correct one
09-13-2016, 12:24 PM
Just call or email Dinosaur and they'll get you the right one.
Gotta go campin!
