Old 02-24-2019, 10:37 AM   #1
Suburban oven issue
Hello everyone! So last season I was using the oven and noticed that the flame on the oven burner was huge! It was out of control. The season befor it worked great but not now. I couldnt cook anything without completly burning it to a crisp. Any ideas where to start on replacing parts? I'm not familiar at all with this oven. Thanks to everyone in advance!
Alwayssummer is offline   Reply With Quote
Old 02-24-2019, 11:07 AM   #2
nomad297's Avatar
How are the flames on the cooktop burners? Are they normal? If so, there may be a seperate regulator for the oven burner that has gone bad. If not, it sounds like the orifice for the oven burner may have fallen out.
Example: https://suburbanrvparts.com/suburban...sembly-521090/
After looking around, it appears there is just one regulator that serves both the top burners and the oven. So, if your top burner flames are unusually high, the regulator is most likely the problem. If they are normal, take a look at the oven burner orifice.
Bruce
Old 02-24-2019, 11:18 AM   #3
Thanks! The cooktop burners work fine. Soon as it gets over -22 I will take a look at the orafice tube!
Old 02-24-2019, 11:43 AM   #4
Trailer Park Supervisor
NJKris's Avatar
sound like you have an orifice problem, as mentioned. If flames are yellow instead of blue, I would suspect a spider made a home in the tube and needs to be cleaned out.
NJKris is offline   Reply With Quote
Old 02-24-2019, 01:50 PM   #5
Ok thanks everyone! Sounds like its probablu an orifice problem. I will start with that. Thanks again!
Old 02-24-2019, 02:01 PM   #6
njfishing's Avatar
2x on a spider building a web in the tube.
Gerry Z
2014 Roo 21DK
Honda Ridgeline
Equalizer WDH
njfishing is offline   Reply With Quote
Old 02-25-2019, 03:40 PM   #7
Head Rambler
Just for safety's sake have the LP system pressure checked to be sure it's at 11" WC.
Gotta go campin!
suburban
