Old 01-12-2018, 03:01 PM   #11
As mentioned above be sure the thermocouple is in the flame. Bend bracket to adjust. A minute should be long enough, but sometimes is not. Try holding it longer if properly in the flame.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 01-12-2018, 03:12 PM   #12
KyDan's Avatar
As mentioned - make sure thermocouple is in the pilot flame.
It should not take a minute.
The OP stated it worked fine until it didn't.
IF the pilot flame looks normal then it just might be a bad TC.
I can release and turn mine to desired temp in about 3 seconds after lighting.
No way am I going to stand/sit/squat there for an entire minute!
Hope you get it working!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-12-2018, 03:59 PM   #13
The Newsoms's Avatar
I have to hold ours in for at least a minute. ~ Teresa
The Newsoms is offline   Reply With Quote
Old 01-12-2018, 04:05 PM   #14
KyDan's Avatar
Wow- I believe you but that's way too long. It should work in mere seconds!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-12-2018, 05:34 PM   #15
Pilot Light
This past summer our 2017 Rockwood with Suburban stove/oven had same problem. I called Suburban since it is under warranty and 700 miles from our dealer. Suburban arranged for RV service in this area. They replaced the thermocouple and no problems until this week. Oven thermometer is 75 degrees off (set at 425 to get it to heat to 350.) Same deal, we called Suburban and they arranged for replacement of the oven burner. I don't know why they don't have a recall because it's a common problem with this appliance apparently according to our service provider.
Two Ole Travelers is offline   Reply With Quote
Old 01-12-2018, 05:36 PM   #16
bikendan's Avatar
Originally Posted by DegaDog View Post
Wouldn't it be nice if Suburban became 21st century and had a DSI lighter like Fusion and Atwood?
Our Atwood stove has DSI for the burners but not the oven.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-12-2018, 05:44 PM   #17
Our issue with the suburban was the front burner won't light via spark. I don't think it's getting one. It's getting gas, so I turn it on, and light it with a Bic lighter. Can't seem to see how to get the top off to get at the capacitor. Maybe that's broke or bent too far from the gas.
Mdaniels4 is offline   Reply With Quote
Old 01-12-2018, 08:13 PM   #18
Thurman's Avatar
One trick that has worked multiple times for me: Take a small piece of aluminum foil, was it up, then reach back and rub this on the t'couple lightly. T'couple can/will get a sooty coating on them and will not read temps correctly.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 01-12-2018, 08:53 PM   #19
Not sure about RV ovens, as I've never looked at mine that hard, but on manual residential gas ovens, you can adjust the knob.
Assuming RV ovens are similar, the knob actually consists of two parts: the actual knob, and a plate that connects to the gas valve. The plate can be rotated relative to the knob. You pull the knob off and on the back, there are usually 2 screws that you loosen, then rotate the plate. You need to rotate it about the same amount as the distance between (in your case) 350 and 425. After some use, you may find you need to do it again to get it exactly where you want it.
UPDATE: Just googled Suburban RV Oven Manual and the one I got says:
2. Operation of Oven Burner
a. Turn the oven control knob counter-clockwise to the desired
setting. Oven burner will come on immediately and the oven burner will
stay on until it reaches the desired setting. Then the oven burner flame
will decrease in size. This is normal for this type of thermostat and this
flame size will maintain a constant temperature withing the oven.
NOTE: Oven thermostat was calibrated at the factory and is not field adjustable.
So I guess you can't adjust it. You need a new thermostat.
2011 Traverse LT, 3.6L, FWD
Old 01-13-2018, 09:23 AM   #20
Wolverine 1945's Avatar
Originally Posted by llr View Post
bad thermocouple(sp). This is what heats up when you hold the knob in and once hot allows gas to flow and if the pilot goes out it cools and cuts the gas.
easy to change depending on access and routing. it runs between the pilot and the oven gas valve (behind the knob and panel) with a thin metal tube in between
Thermocouple may just be dirty,,, they can be cleaned with a pic of steel sandpaper !!! Also I wonder if you need batteries for your oven to work ???
Wolverine 1945 is offline   Reply With Quote
light, pilot light, suburban
