Old 05-26-2015, 11:07 AM   #1
Suburban oven won't light
Ok folks... My 2015 FR. Vibe has a suburban gas stove/oven combo. My burners all work fine, the exterior gas grill works great, and the furnace and hot water heater all work fine, but the pilot for the stove just won't take. It will stay lit as long as you are holding in the knob, but as soon as you release it it goes out. Any similar situations or suggestions?
Thanks in advance!
The BadgerCamper.
shadowrad69 is offline   Reply With Quote
Old 05-26-2015, 11:11 AM   #2
Mine did the same thing, I have a 2015 EVO. I just kept trying and finally after like 10-15 tries over a 30 minute period it worked. I dont know what the problem was but I have camped 3 times since and it has worked fine since then.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 05-26-2015, 11:12 AM   #3
I tried (no joke) about 40 times to get it to take.. I was so mad I was ready to load it with tannerite and get a new one....lol
Old 05-26-2015, 11:15 AM   #4
Thermocouple
2019.5 Rockwood 2509S
Toddupton is online now   Reply With Quote
Old 05-26-2015, 11:44 AM   #5
Does the burner light, like if you just turn the stove on and hold the lighter to the burner? I think I did that to see if that worked and then I shut it off and that's when I tried to relight the pilot and it worked if I remember right. I cant rememeber. I may even have done it wrong, this is the first TT I have had with a stove. I believe that is what I did though.
Old 05-26-2015, 11:46 AM   #6
V-Nose Newbie
davidl1957's Avatar
Smile
Shadow,
Just bend the thermocouple bracket slightly so that the thermocouple is in the pilot flame. That should take care of it!
Living and loving life,
Dave, Sue and Peanut the wonder dog
davidl1957 is offline   Reply With Quote
Old 05-26-2015, 11:50 AM   #7
Yeah.... I've no clue what that looks like.... not even gonna lie.... Suicide, the burner sort of lit during a few of the pilot attempts, but it would flicker down the length of the tube.
Old 05-26-2015, 11:58 AM   #8
suburban gas oven not lighting
I had the same problem and took it back to the dealer and they replaced the orifice because the hole was to small and would not let enough gas through. works perfect now
tman606 is offline   Reply With Quote
Old 05-26-2015, 12:02 PM   #9
V-Nose Newbie
davidl1957's Avatar
No problem, most thermocouples are cylindrical in shape with a small DC wire coming out of them to the burner control. You should be able to easily locate it. Give it a little tweak and you should be good as new. It's possible that you have a defective thermocouple, but doubtful. Juts hold the knob in and light the pilot and you should easily see the thermocouple, if it is not in the flame it will not generate the very love voltage signal back to the the burner control. Take you time and look around, you'll find it.
Old 05-26-2015, 12:26 PM   #10
You can take the thermo cuplour out on the end at pilot light and the small wire should come out when heated with llighter. Also if there is a kink in it tbis wire can't come out
This small bulb is what hhholds the gas valve open.
Myrle is offline   Reply With Quote
light, suburban
