Old 11-05-2017, 08:28 PM   #1
Suburban stove flame to low from pot
The flame, when on high, is no where close to the bottom of the pot. So I can't heat up any food. There is a metal tab underneath the stove top. Is it supposed to "latch" down into the stove? Mine is just resting on it.
cpenn43 is offline   Reply With Quote
Old 11-05-2017, 11:27 PM   #2
B D HOWie's Avatar
I recommend posting a few pictures of the stove top, tabs, and how it looks where they join to help others see your stove.
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 11-13-2017, 02:54 PM   #3
pics
Here are some pics of my issue. The flame does not reach the bottom of the pot, therefore the food does not heat. There is a metal latch type thing and a notch, but I don't know if it is supposed to latch down or not. I can't get it to "latch" and I don't want to force it if it is not supposed to be. Thanks for your help.
ID:	156361   Click image for larger version
ID:	156362   Click image for larger version
ID:	156363   Click image for larger version
Old 08-07-2018, 10:53 AM   #4
Did you ever resolve this? I have the same problem and I was assuming my burners were not putting out enough flame.
cbiehn is offline   Reply With Quote
Old 08-08-2018, 01:07 PM   #5
Head Rambler
The first thing I'd do is check the gas pressure. It should be 11" WC (water column). Especially if it worked in the past and now doesn't.
Gotta go campin!
Old 08-08-2018, 02:10 PM   #6
Yes, I did. When inserting the grate, I was putting the back in the slots first and could not get the front latch to snap down. So I finally put the front latch in first and then did the back and it worked. So the trick is to start at the front when reinstalling the grate.
suburban
