Originally Posted by geewizard
Is it normal for the Suburban cooktop to be hard to adjust to a simmer?
Ours seem to be either on high or off and seems very sensitive to adjust to a simmer.
You have to fool it. After lighting the burner, let it run high for 30 sec. or so to heat up. Then s-l-o-o-o-w-l-y turn the knob towards "off." You will see the flame die down. Stop it where you want it. Takes a couple of times to master the technique but it works. As dalford noted, it will be susceptible to blow outs.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
