Old 10-08-2016, 01:39 PM   #1
Suburban stove won't simmer
We're new to Rpods and have a used 2011 172.
Is it normal for the Suburban cooktop to be hard to adjust to a simmer?
Ours seem to be either on high or off and seems very sensitive to adjust to a simmer.
geewizard is offline   Reply With Quote
Old 10-08-2016, 01:47 PM   #2
The front burner is your hottest burner so select on of the rear burners and turn to low. Remove the knob and look down the center and you can see a slot to adjust the flame height with a small flat blade screw driver...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 10-08-2016, 01:49 PM   #3
Great! thanks.
Old 10-08-2016, 01:54 PM   #4
Just don't turn it too low.. sometimes when you do that and you open and close the oven door to hard it will blow out from draft since the top is not sealed.
2016 Siverback 33IK
Old 10-08-2016, 07:32 PM   #5
Head Rambler
Don't beat me up, but lets make sure you're adjusting it correctly.
On most RV stoves you turn the knob counterclockwise from Off to Lite/Hi and then keep turning it counterclockwise to Low. When I first started out with one of these I thought you turned it to Lite/Hi then back clockwise to adjust the flame height.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-09-2016, 10:47 AM   #6
I have only two burners and neither control has an adjustment under the knob.
Old 10-09-2016, 10:48 AM   #7
Never one to beat up.....my stove control doesn't work that way. It turns CCW to Light/Hi but then back CW to low or off.
Old 10-09-2016, 10:59 AM   #8
Sorry to hear. Looks like you may be stuck with a hot low setting. I did look up the Suburban 2 burner stove (SD2) and it did not have flame height adjustment instructions.
2016 Siverback 33IK
Old 10-09-2016, 02:12 PM   #9
No wonder my burns every time.
2 Old Geezers
2 Labradorables
2015 Dodge Ram 1500-Rambo
2015 Roo 21BD-L'ABode
lablover is offline   Reply With Quote
Old 10-09-2016, 02:14 PM   #10
That would be rice
2 Old Geezers
2 Labradorables
suburban
