Old 07-08-2019, 09:16 PM   #1
Suburban sw6d wonít stay lit
I have a suburban sw6d water heater. It will light but after a couple seconds will kick out. Try multiple times and same problem. Looked at the control module and everything seems to be good there. What direction should I look next?
Wildinc13 is offline   Reply With Quote
Old 07-09-2019, 12:53 PM   #2
Head Rambler
Does it re-fire every time for a few seconds, or do you have to do something to get it to restart?
It could be that the igniter needs cleaning and/or adjusting. It's part of the flame sense, so if it doesn't sense a flame it closes the gas valve after a few seconds.
It should have a 1/8" gap and the rod should be clean. Fine emery cloth usually works.
You can find a service manual online for these heaters.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-09-2019, 02:59 PM   #3
Yes it will refire everytime for a couple seconds. Then after the third time it wonít try to relight. If I turn the switch off then back on it will do the same thing
Old 07-09-2019, 03:08 PM   #4
Thurman's Avatar
Yep, clean the flame sensor and try again. If it still won't stay out you probably need a newcomer sensor or control board. Controllers can go bad and appear perfect. No known control board test for consumers at this time
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 07-09-2019, 03:19 PM   #5
Where is the flame sensor on the water heater?
Old 07-09-2019, 03:58 PM   #6
Just as confused as you
Scrapper's Avatar
Flame sensor and the igniter are the same part. Service manual for your SW6D and other models is in the Library section of this forum.
Forest River Forums - Downloads - WH_Service and Training Manual 05-18-11.pdf
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
suburban
