Originally Posted by bpa098
Just when I think I figured out my water heater. Boondocking. Battery is brand new. Have propane. Have water in water heater. Ok flipped on water heater switch inside camper, fault light came on instantly. Just wait 5 mins or do I have to unhook battery and turn off propane tanks, instructions say kill power and propane and wait 5 mins. Already checked reset button
The fault light does come on as soon as you flip the switch and will stay on until the propane lights...usually 15-30 seconds. After that, it goes off.
If the propane doesn't light in the initial try, the DSI will Usually attempt two more times with a delay between each try. If AFTER three failed attempts, the propane/dsi goes into lockout mode...and then you have to turn the switch off and back on after a few second delay to reset the lockout.
We just discussed this in another thread a few days ago. Let me find it.
EDIT: Here you go. See if this thread helps:
http://www.forestriverforums.com/for...ues-88528.html
