Old 06-23-2015, 07:54 AM   #1
Sunseeker mb 24rs air conditioner runs
Should the fan run all the time even after the compressor turns off? Unit has a thermostat and it is set to "auto"
oregonct is offline   Reply With Quote
Old 06-23-2015, 08:11 AM   #2
Your thermostat could possibly be set to "manual" fan setting which would make the fan run all of the time. If you only want it to run when the AC is running set it to "auto". I hope this helps.
bop11 is offline   Reply With Quote
Old 06-23-2015, 08:12 AM   #3
Ops! Sorry I didn't see that your thermostat was set on auto.
Old 06-23-2015, 08:30 PM   #4
No problem. Thanks for trying Do does your unit run all the time when on Auto?
Old 06-23-2015, 09:24 PM   #5
I have a Cardinal 5th wheel but my fan turns on and off with the compressor. i would believe that something is wrong either with your thermostat or a sticking run solenoid in the fan circuit within the AC unit.
Old 06-23-2015, 09:28 PM   #6
Thanks much!!
Old 06-24-2015, 12:44 PM   #7
I recently installed a new single zone thermostat in my 5th wheel and the fan kept running even though the compressor came on and off as it was supposed to. After rechecking everything I found out I had the thermostat set on auto but the fan had a separate setting and I had that on the on position, switched it to auto and booyah it worked perfectly. Hope your problem turns out to be that simple.
scrappypappy is offline   Reply With Quote
air conditioner, sunseeker
