Old 08-20-2012, 07:32 PM   #1
great white's Avatar
Surge protector- 30 or 50 A?
I find myself wanting to buy a surge protector for the TT.
I've never had a problem hooking up, but I don't want to have one in the future either.
So, do I need a 30 or 50A for my 2011 831RLBSS?
Or is it more dependent on what kind of hook up you get?
For example, there's only 50A service sites left and I've got a 30A surge protector. Is that a problem?
I think my trailer only needs a 30A service, it's always run fine on 30 A.
Whichever I need, it will be a "wired in" not one that hangs outside.
I just don't want to get a 30A surge protector and burn it out becasue I hook it up to a 50A.
Or do I just not understand what's going on here at all?
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-20-2012, 07:54 PM   #2
papap's Avatar
that is how mine is set up. have not had any problems.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-20-2012, 08:42 PM   #3
Unless there is something unusual, such as two A/C units, your trailer should be 30 amp and you would need a 30 amp surge protector. In order to connect to a 50 amp receptacle you would have to have an adapter. The 50 amp electrical pedestals I have seen also have a 30 amp receptacle.
Paul & Anne
2011 Flagstaff 831RLSS
2013 F150 SuperCrew Lariat 4x4 3.5L EcoBoost Max Tow 157"wb
hokiecampers is offline   Reply With Quote
Old 08-20-2012, 11:18 PM   #4
B47
Doesn't your TT have a placard near the external power plug receptable stating what your unit is rated for - 30 or 50 Amp?
IMO - regardless of what your unit is rated for, I would spend the extra money for the 50 Amp model - might save you from having to buy a 50 Amp model if/when you upgrade something electrical or buy a unit that requires a 50 Amp model.
Old 08-21-2012, 03:40 AM   #5
Well duh on me.
I just realized my plug is 3 prong, so 30a.
Thinking back to electrical theory (that's a looong time ago for me) I seem to remember that a component will only draw as much amps as required. The extra on the line remains potential.
So, I will have to read up on it but if my trailer is rated a max draw of 30a then a 30a protector should be ok even when adapted to a 50a plug in....
Old 08-21-2012, 05:32 AM   #6
EJM4's Avatar
Well duh on me.
If your trailer is only 30 amps that is all you will need. We use the Progressive Industries surge protector for our coach.
Progressive Industries SSP30 Smart Surge : Amazon.com : Automotive
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 08-21-2012, 06:28 AM   #7
Herk7769's Avatar
Well duh on me.
This exactly right. If you have a 30 amp camper, you will need a 30 amp surge suppressor if you hard wire it in.
A 50 amp suppressor unit would "work" but you would only be using half of the suppressor when you wire it up. You could then remove it and re-install it in your new 50 amp camper one day. However, you would be paying a LOT more for your 50 amp suppressor with no idea if you will ever buy a 50 amp camper. (You may just get another 30). Even if you did, that "New Camper" may come with one standard by then.
HAM CALLSIGN - KC3FFW
Old 08-21-2012, 07:05 AM   #8
Wanna Be Camper
SaskCampers's Avatar
If going internal the Progressive Industries EMS HW30C is a great unit. Put one in our unit prior to our trip to Indiana and it is sure nice to know when you plug in that all is ok. I have ours set for a 136 sec delay so if the power goes off it gives the ac a chance to equalize pressue a bit.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
