02-01-2012, 10:04 AM
Sw12de suburban water heater
I have a 2011 SWDE Suburban water heater in my fifth wheel and it has a water heater that is both propane and electric. I have put (2) high limit/thermostat switches on the 110v side since I have had it. What is happenning is the thermostat connection on the side that is connected to the high limit switch is getting hot and burning out, not the solid wire piece that is connecting them both together but by the terminal that has the solid wire welded to it by the manufacter on the thermostat. I have checked the amp draw form the element and it is drawing 11.45 amps which is normal for a 110v 1440 watt element. What could the problem?
02-01-2012, 10:39 AM
Moderator
What is the current rating on the thermostat? Sounds like that is where the problem is.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
02-01-2012, 01:26 PM
The thermostat is preset at 130 degrees and is for 110v
02-01-2012, 04:36 PM
Moderator
Understand the voltage, and the temp, but it should also have a current rating. It may be listed as 1000 watts for example, and then your electric element is too large, since you stated you have a 1440 watt element.
Windrider,
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
02-02-2012, 12:36 PM
Dallas Texas
As Windrider mentioned the wattage may not be correct for the switch. Normally the wattage is stamped on the side. Have you seen any heat marks or degradation on the female connector?
2003 Cardinal 33CKT
2006 Ford SD F250 CC 4WD
2001 Coleman Santa Fe (to be sold)
1984 Honda Magna V65
1963 M50 Harley Davisdon
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 621 |
| 152 members and 469 guests |
| 1l243, 4bnabird, 87CrewDually, alphadog99, alpinemike, autorot8, baldy, Bchecker, bclemens, Big Dawg, Big Vic, BigDogD, bka4tcu, bonfirebunch, bouldercamper, buzzmonster, bwhunter65, camper1999, camping4us, Capsfloyd, capucine, case1175, Catman86, cbconway, ChiefGeek, chiro, Chrylser_91, cpaulsen, CRZ, dansa122, daveinpickerington, davidjb, ddemme, dec1952, DGrissom, Dhudglr, digger47, djorgensen3, dman114, donh, Douglasdh62, dunnnc, Earth Station, Falcon35, feerobk, Filthy Beast, Fire Instructor, frankt, FreedomTracker, gamller36, Great Horned Owl, Greywolfmn, Happy Vibe, harleyvette, hokiecampers, House97, JamesR, Janet H, jar3316, Jeep4Two, JeffK, jfischer, joelabq, jojo bamboo, judy3972, kanati, ken0042, Kevin-and-Julie, kixonrt66, KKapa, KoolAide, kozzy, Labzy, Larryvsr, LauraW, leennp, lesameinze, LFugate, lindy, LKicklight, lochsa, Lonewolfcry, Marsarch, melbornj, MikeFletcher24, MikeT, missy9249, Moracechaney, Mountainmanbob, mraynie, mtnguy, myredracer, nailit, ncgrl1, NeilM108, NorminN.B., OregonCamper, pappcam, patmo2000, Pinesman, Poppy Bill, punkaccountant, racer30, rawlus, rerger, RGH, rjshiflet, rob2112, ROCKIN 34, rockin'ray, ronhanson, rotorhead1250, sandys, scorekeeper81, SDENN4281, Selib1, sherri330, silverwing, Snowsail, softwarejoe, sprayking, steeljag, Stevea1956, Superchief, tblkfsh, Tee, tentcamper1, thehamguy1, thumper, Titleguy, tls5150, tmmar, Tom47, tonybab, Tracer, Traci, trailertrash78, travyp, Triguy, T_LMurphy, u0179187, unhcharger25, Unruly, venturetaz, Vette4trcr, VRMHW-M, VTX Al, wfmdfm, Wildcat Chris, Wilkrich, windrider, yworrydog |
| Most users ever online was 996, Today at 11:04 AM. |
