Old 05-26-2016, 07:57 AM   #1
System monitor
Hi, I am new to trailers so pardon my question. We checked the water levels and the battery power and the battery check lights have stayed on. Is this an issue? Or will it turn off eventually? Or do we have to disconnect the battery to make the lights go off? Thanks in advance!
Sonworshiper is offline   Reply With Quote
Old 05-26-2016, 08:07 AM   #2
Mr. Dan's Avatar
That's not normal. Is there any chance the button you pressed to check battery level merely stuck in?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 05-26-2016, 08:30 AM   #3
The button still clicks so it does not seem stuck. Should we be concerned or is it just stuck lights?
Old 05-26-2016, 09:36 AM   #4
Head Rambler
I'd try unhooking from shore power and the battery temporarily and then hooking the battery back up and see if it works normally. I suspect there's a problem with the panel, but it'd be worth a little troubleshooting.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-28-2016, 05:29 AM   #5
My hubby stopped in at the dealer and asked him about this issue. He said that if you hold the battery check button down for more than 5 seconds it will stay on.
It is no longer staying on and we no longer hold it down for more than a couple of seconds!
"Home is where we park it!"
Clipper 17FQ / Mazda B4000 4x4
Old 07-28-2016, 08:07 AM   #6
Head Rambler
Thanks for letting us know that. I had no idea that holding the button down latched it on.
Does it eventually go off on it's on or is there a sequence to turn it off. Like holding the button down again.
Gotta go campin!
Old 07-28-2016, 08:13 AM   #7
BandJCarm's Avatar
Well I'll be.
Had no idea.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-28-2016, 09:05 AM   #8
I don't think there is a way to turn it off . . .we disconnected the battery.
Old 07-28-2016, 09:08 AM   #9
wmtire's Avatar
Thanks for sharing. Never knew this, and I will be testing mine when I get home.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
