Old 07-21-2016, 11:01 PM   #1
Television reception
TV worked fine at my last stop using the antenna. I can't get reception at my current stop. My neighbor has good reception in his rig. We are traveling together so I am sure he is not cable. We have no cable here. He has an older style antenna which he has to raise. I have a stationary antenna.
HELP !
2015 Surveyor Cadet 294QBLE
2013 F 250 Crew,6.7 , 4X4
Squid701 is offline   Reply With Quote
Old 07-21-2016, 11:08 PM   #2
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
He may have an amplifier on the coax coming from his antenna. Huge difference. It doesn't take much to reduce the reception of over-the-air tv signals.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 07-21-2016, 11:42 PM   #3
rsdata's Avatar
the ability to raise and turn antenna in the direction of the signal source is a huge factor... along with an antenna amplifier... even the make/model of TV is a factor and it's ability to show weak signals on the screen
make/buy/borrow a long 20-50 feet antenna jumper/extension wire and hook to his antenna with your TV and do some comparisons... should be able to buy something like that at Wally world
make sure you have scanned for channels on the digital tuner first
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
reception, television
