Old 04-21-2014, 08:17 PM   #1
Test Fridge Running Off Battery?
Hello everyone,
I am having an issue with my fridge running off my truck. Every time I run the fridge off the truck it thaws out and I end up with a lot of ruined food. This happened twice to me. The first time I thought I did something wrong, the second time I knew something else is wrong.
My question is how can I test this? Can I hook a charger to the battery and let the fridge run on 12v or will I damage something having the charger hooked up while running it? Is there anything specific I should be looking for?
It runs on 120v and propane without issue. But doesn't the 120v run through 12v converter?
I tested the truck power and it is fine there so I need to test the fridge itself somehow before I take it in for warranty.
Thanks for all your help
Steve A is offline   Reply With Quote
Old 04-21-2014, 08:18 PM   #2
Todouble's Avatar
Mine runs on 120v shore power or while traveling down the road it runs on propane. Most are setup this way. Very few run on 12v dc
Todouble is offline   Reply With Quote
Old 04-21-2014, 08:22 PM   #3
I can also run it on propane while traveling but I would prefer to use the 12v system and being that the camper is only a few months old I can take it in for warranty repair but I want to make sure I covered all my bases before taking it in. Just in case I am overlooking something.
Old 04-21-2014, 08:25 PM   #4
Todouble's Avatar
What's the model of fridge? I don't think you have the 12v option. It uses 12v to light the flame and power the fridge but uses propane for the heat source to transfer the refrigerant around. Usually the 12v option to run the fridge is on motor homes with lots of batteries
Old 04-21-2014, 08:30 PM   #5
It has the 12v for traveling.
So for the sake of the thread lets just say I do have a 12v system, what steps would I need to take to test it?
Old 04-21-2014, 08:37 PM   #6
Todouble's Avatar
We all have a 12v for traveling but it's only uses the 12v to power the controls of the fridge. You must heat the ammonia refrigerant that's in it to work. Thus only being accomplished by a propane pilot flame or 120v shore power. The demand on a 12v batter as the heating element would drain it pretty darn fast. What's your model of the fridge or camper so I can give you a definite answer. But everything your describing tells me you don't have a 12v dc as a heating element. Only fridge controls
Old 04-21-2014, 08:41 PM   #7
Todouble's Avatar
Does the top if your fridge have an on/off button and then another button next to it that says auto/ gas??
Old 04-21-2014, 08:50 PM   #8
Herk7769's Avatar
Dometic RV fridges require 12 volts to work the electronics, BUT you need a way to heat the ammonia too. This is accomplished two ways: propane OR a 120 volt AC heater.
When running on truck 12 volt DC you MUST have the propane on.
If the propane is turned off at the bottle; no workie...
You need 12 volt DC when running on shore power too. That is provided by the converter.
I always run in AUTO with the "GAS" button OFF. This way the fridge will cool with 120 volts (if available) and "auto" switch to DC and GAS if the shore power fails or you are disconnected and towing. ALWAYS leave the AUTO button on as it is really an ON/OFF button.
The GAS button is only used when you have shore power BUT the voltage is low (say) and you want it to run on gas ANYWAY even though shore power is available.
Name:	913th 3rd Annual Picnic and Camper photos 033.jpg
ID:	50643   Click image for larger version
Name:	Circuit diagram.jpg
HAM CALLSIGN - KC3FFW
Old 04-21-2014, 08:59 PM   #9
I'm going to guess that steve has a popup as some of those have 3 way fridges. You have the switches on the outside the switch between gas, 120 and 12V. The 12V is only used while traveling so you are using the power from the TV. You could run the system from an external 12v source, ie battery charger. After 15 or 20 min you should feel the vent tube in the fridge compatment heat up. If it does not heat up you need to find the two wires going to the 12V heater and do a resistance measurment on it. If you get a high resistance than the heater is no good. If the resistance is low than you may have a bad switch.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-21-2014, 09:05 PM   #10
Great, thank you Happy Vibe. I will be pulling it out of storage this week so I will have more information on the fridge then but I just wanted to make sure that I wouldn't damage anything by having a battery charger connected while running the fridge. I know it should be the same as having the truck hooked up to it but I rather be safe than sorry. And I rather not take it in for warranty work if it is a easy fix.
battery, fridge
