Old 07-30-2015, 04:16 PM   #1
Thermofuse
My Dometic refrigerator will not stay on, I replaced the thermo fuse and it came back on for 1/2 hour and all power was lost because it tripped the thermo fuse again. from what I have found so far was that I need to replace the cooling unit but that is unsatisfactory. Anyone know anything else I can try? Heating element, or is there a fan I can check? Thanks
Nick Norwil is offline   Reply With Quote
Old 07-30-2015, 04:33 PM   #2
fonzie's Avatar
You might find the info you are looking for here....
RV Absorption Refrigerator Reconditioning Training Center
http://rvrefrigeration.com/training-videos/
Fonzie
Old 07-30-2015, 04:44 PM   #3
I've been in his website all day but nothing on the thermofuse. Thanks though
Old 07-30-2015, 05:23 PM   #4
Will it function on propane. If so, then I think your problem is on the 110v side. Sorry, just read that is on the 12v side. Found this Dometic refrigerator blowing fuse!
Dometic DM2652 RV Refrigerator Repair - Faulty Electric Heater Element
Old 07-31-2015, 09:18 AM   #5
no, unfortunately it will not. There is no power. Although I have not tried to start it with propane. I will try that if I can get it to turn on. Thank you
Old 07-31-2015, 10:16 AM   #6
Crockett's Avatar
you can just bypass the fuse to test. but a better test would be to just run the core direct electric. thats the standard test for a core. 110 straight to the element.
Crockett is offline   Reply With Quote
fuse
