Old 02-19-2019, 04:19 PM   #1
Bonjoey's Avatar
Thermostat atwood/dometic question
Our new to us sunseeker have this thermostat (attached) and for some odd reason the furnace “light” wont turn on or either burnt. We spent a really cold night couple days ago (-4F) and the furnace did run but having hard time keeping up with the frigid temp.
Also does any one know how the timer works? Cant find a manual for it.
Bonjoey is offline   Reply With Quote
Old 02-19-2019, 04:36 PM   #2
if the furnace works then it's just the indicator light that's out. Did the furnace blow hot air? Did it blow it all night or cycle on/off before reaching temp? You might have a furnace problem in addition to a burned out indicator light. I've never seen a panel like that.
nayther is offline   Reply With Quote
Old 02-19-2019, 04:47 PM   #3
Bonjoey's Avatar
It did blow hot air all night but i noticed it does cycle on/off but the fan kept running all night. It’s like a home high efficiency furnace where the fan still blows and warm air coming out then once in a while the furnace clicks then you can hear the flame goes
Old 02-21-2019, 09:19 AM   #4
Bonjoey's Avatar
I had an answer from the dealer about the furnace light.
Anyone knows how the timer works?
Old 02-21-2019, 11:01 AM   #5
Head Rambler
Since the only place I've seen that thermostat is in motorhomes, you may get more info on it if you ask one of the mods to move this thread to the correct motorhome section.
Gotta go campin!
Old 02-21-2019, 12:35 PM   #6
Just as confused as you
Scrapper's Avatar
You have your "new to us Sunseeker" in your profile as a 2019 FR Sunseeker 2650CDWS E450SD. Most rv's don't come with a manual specifically for the thermostats. Why, I don't know since there are many different styles and types of thermostats used in rv's.
That said, I found a Atwood-Roof-Air-Conditioner-AC1351-and-AC1501-Manual. Operation of your thermostat is on page 11 of the attached manual.
Richard & Jill
Camping since 1989, seasonal since 2000
dometic, thermostat
