Old 05-18-2019, 08:06 PM   #1
Thermostat E1 Error Code
A/C cut off and Dometic thermostat reads E1 for zones 1 & 2. We reset the breaker for both zones and followed the reset instructions on the thermostat. The final step is to turn the thermostat back on. After doing that, it still shows Off and Zone 4 (we only have 1 & 2). Press it again and there's no display at all. Any suggestions? This hasn't happened b4. Thanks.
DHSDawg is offline   Reply With Quote
Old 05-21-2019, 12:10 PM   #2
Head Rambler
There have been a few instances where unhooking the cable at both ends and cleaning the connections and hooking them back up has fixed that problem. However, in a lot of cases the thermostat is bad and has to be replaced.
Gotta go campin!
Old 05-24-2019, 01:06 PM   #3
E1 error code
I am having the same problem with mine. Getting E1 for Zone 1 & 2; zone 3 works fine. Replaced thermostat and having same problem still. Any ideas
Stevebuery is offline   Reply With Quote
Old 05-24-2019, 01:10 PM   #4
The night this happened, we turned the thermostat Off and left it that way about an hour. When we turned it back on, it started to work correctly. Has been fine since. Still have no clue what happened with it.
Old 05-24-2019, 02:54 PM   #5
Check clean control cable where they connect to ac control board. Common problem.
httntheroad is offline   Reply With Quote
Old 05-24-2019, 02:58 PM   #6
Thanks. I'll keep your info and do that.
Old 05-24-2019, 03:00 PM   #7
Thanks. We're going to do this in hopes it won't happen again.
thermostat
